help with gutting rear cats?
Old 05-27-2010 | 03:46 PM
Crossfire725's Avatar
Default help with gutting rear cats?
Can some one please explain to me on how I would go on gutting my rear cars. Like how to do it. Please. Thank you very much.
Old 05-27-2010 | 08:08 PM
Default Re: help with gutting rear cats?
please help
Old 05-27-2010 | 08:31 PM
subeman's Avatar
psst if you ask google it will tell you. "how do I gut a catalytic converter"
Old 05-27-2010 | 08:39 PM
i know you have to beat it with a pole. but there is a curve in the exhaust i am wondering on how people went by this and what they used to make it work
Old 05-27-2010 | 10:35 PM
xxfire72's Avatar
How to gut the cats....first remove the exhaust from the car...next you will need a grinder with a cut off wheel to cut a 4 inch by 4 inch square on the cats...save the pieces you will need to weld them back on....once you have the square cut out you will expose the guts in the cat...take a screwdriver or chisel with a hammer and break up the guts...make sure you get it all out...weld the squares that you cut out back on n bolt it back up...done
Old 05-27-2010 | 10:36 PM
glockster's Avatar
So I'm new around here and have a lot to learn but why would you want to "gut" your cats? They are there for a reason.
Old 05-27-2010 | 10:39 PM
xxfire72's Avatar
Better exhaust flow..nice sound..more hp
I don't have a welder and I don't wanna cut a hole in my cat. Is there an easier way. I have a crossfire n/a. Please help, thanks
Old 05-27-2010 | 10:41 PM
P-J's Avatar
P-J
less back pressure = more horsepower
Old 05-28-2010 | 12:40 AM
Can I get some ways on how to do this, thank you for your time
Old 05-28-2010 | 12:41 AM
NeedsWings's Avatar
wear a breathing respirator, when the converter material is broken up the dust causes cancer if inhaled. or so i have been warned
Old 05-28-2010 | 06:50 AM
Thanks for the heads up bro, you seem to know a lot and you do help me a lot so I thank you. Do you have some insite on the best way and easiest way and what to use to gut the rear cats? Cause dose the y pipe make it like impossible to put a pipe down either side?
Old 05-28-2010 | 11:45 AM
NeedsWings's Avatar
id cut out the cats, replace with stainless straight tubing and sell the cats to the scap yard and get reimbursed for the project
Old 05-28-2010 | 11:48 AM
But I don't have a welder or wanna pay someone to do it
Old 05-28-2010 | 12:20 PM
rfors777's Avatar
They have all answered your question already. If you don't want to cut them and weld them back, then don't do it. You are not going to gut them without removing the exhaust and having to cut and weld.
If you are not willing to do this, or pay someone to do it, stop asking about it.
Old 05-28-2010 | 01:58 PM
I have a small vial of unicorn tears, if dripped in just the right position, you can melt right through those pesky old catalytic converters
Old 05-28-2010 | 02:36 PM
oppizzippo's Avatar
I'd suggest finding someone who has a welder and buy some pipe and cut out the cat and sell it for junk. The cat contains platinum making them more valuable than they look.
OR
You could invest in a welder.
OR
You could find a community college or high school auto shop and talk them into doing it for next to nothing.
Cory
Old 05-30-2010 | 11:12 AM
i got it done. thank you to everyone. i used a piece of metal rebar cut a point in it with a saw and pounded the **** out of both rear cats. used a bigger pole to break the pieces so they were about to come out. both cats took me about an hour not on a lift off of the ground on jack stands. used a vac like people said and turned the car on at times to shoot everything all out. thanks to everyone
Old 05-30-2010 | 11:26 AM
subeman's Avatar
...and does it run better?
Old 05-30-2010 | 12:07 PM
waldig's Avatar
Talking Re: help with gutting rear cats?
Told ya u could do it. Enjoy da sound n pwr gain. Woody
Quick Reply: help with gutting rear cats?
