Turbo?
Old 01-20-2010 | 10:19 AM
tom2112's Avatar
She can ride with me ;)
Default Re: Turbo?
Hey Franc, not to bust your chops or anything, but where'd you come up with those numbers?
If you're car dyno'd at 193.5 whp then your crank hp would be approx. 236, not 290. Wheel horse power numbers are roughly 82% of crank horse power numbers (which accounts for 18% drive train loss).
The other numbers you posted don't make sense to me.
Originally Posted by Franc
The posted nubers for the NA crossfire are 215 HP while the SLK boasts 229. There is not difference except a perception created by marketing. So using the 229 HP number you get 287.7370 HP.
Even using the 215 HP you get 270HP. Not really "Pushing 300 HP" Still impressive.
The 215 and 229 numbers are crank hp numbers published by the manufacturer - not rear wheel hp numbers. If they were to put those cars on a dyno, they would read roughly 18% less for rear-wheel horse power numbers, such as 176 and 188. Of course, every dyno is a little different, so allow a couple % variation, but you get my point.
So I don't understand your reference to 215 pushing 300.
Old 01-20-2010 | 10:43 AM
JHM2K's Avatar
Default Re: Turbo?
I went back and ran the numbers as well. Ignoring the SLK numbers and simply sticking to our "alleged" 215HP, I compared baseline crank HP with his measured baseline wheel HP.
154RWHP / 215Crank-HP = .71 x 100 = 71%
That's a whopping 29% parasitic drivetrain loss... Is that even possible?!?
Based on 18% losses, which is industry average for a manual, one should be seeing ~175 RWHP from the factory, right?
Even applying that catastrophic correction figure to the 'post-tune' numbers of 193.5 RWHP, I came up with:
193.5 x 1.29 (to correct for previously calculated drivetrain losses of 29%) = grand total of 249.6 Crank HP...
249.6 - 215 (factory claim) = net gain of 34.6 HP.... Not shabby, but not even close to 280.
That's my math... if anyone disagrees, I'm open for suggestions.
Old 01-20-2010 | 12:41 PM
tom2112's Avatar
Default Re: Turbo?
You're right JHM. His initial dyno number is low. But that may be due to the dyno - different brands read vastly different numbers. I can never remember which brand reads high or low or whatever.
Probably the best way to compare the numbers to crank numbers is to assume that Franc's car was running at manufacturer's spec when he initially had it dyno'd. So it was producing 215 crank hp and dyno'd at 154 whp.
After his mods, he dyno'd at 193.5, which is a 39.5 whp increase, which is a 25.6% increase over his stock numbers. If we increase the stock crank hp (215) by 25.6% that gives 270 crank hp. That's still not 290, but what the heck.
Franc: were your dyno's both done on the same day? Did they dyno it stock, then put all of the mods on it and dyno it again? Or were they different dynos on different days?
amx1397
Other Vehicles
07-24-2020 09:25 AM
zackman62
11-06-2015 12:37 PM
grip grip
Other Cars
09-26-2015 09:52 PM
xjken
09-01-2015 10:40 AM
MI1XFIRE
08-02-2015 11:05 AM
Quick Reply: Turbo?
