How to remove center console / How to replace side mirror switch
Old 11-20-2011 | 11:56 PM
spankgo's Avatar
Default Re: How to remove center console / How to replace side mirror switch
my mirror switch was pushed down into the console by a friend who thought it was the window button
I tried pulling it up to click it back in place (like my window buttons that pop out occasionally), but the mirror switch did not pop back into place like i was hoping. Has anyone experienced this? the switch still works but will i have to replace the entire piece for it to fit snuggly again?
Old 11-06-2015 | 04:51 PM
Flamenco2005's Avatar
Default Re: How to remove center console / How to replace Side Mirror switch
In this pic under the console. Is the Airbag control module under there? Or is it under the radiko. I can't find any specifics anywhere.
Old 11-06-2015 | 05:08 PM
This should show you what you want to know.
CLICK
Old 11-08-2015 | 12:55 PM
Thanks, i can use this down the road. After looking
it does not tell me wear it is. It shows a diagram of
exterior of the car. Pointing more or less where it is located
pointing to the outside of the car. No other reference
is mentioned.
Old 11-08-2015 | 01:18 PM
JEFASOLD's Avatar
0ne little note for anyone reading this thread for console removal, the 2 bolts are 10mm as everything on this car is metric.
Old 11-08-2015 | 04:34 PM
is mentioned.
If this is the part it tells you where it is.
Occupant Restraint Controller - Under center console. See Fig. 8 .
Old 11-08-2015 | 06:52 PM
Oh ok....I was looking for Airbag control Module. No wonder! Duh!
Thanks again.
Old 10-28-2016 | 10:00 AM
mocha2112's Avatar
how do you do this for automatic???
Old 10-28-2016 | 10:37 AM
The same way.
Old 05-19-2020 | 03:39 PM
mariontr's Avatar
So the question I pose is since it is an automatic do you have to remove the thin bezel trim around the gear **** first or just remove the entire assembly in the picture #3 posted by Musclefan21?
Old 05-19-2020 | 03:47 PM
Yes. ....
Old 05-19-2020 | 06:24 PM
mariontr's Avatar
Yes as in remove the thin bezel first or yes to remove just the entire assembly which includes not removing the thin bezel?
Old 05-19-2020 | 07:36 PM
Sorry.
Yes, thin bezel first.
Old 05-19-2020 | 07:52 PM
mariontr's Avatar
Thanks, onehundred80
Old 05-21-2020 | 10:44 AM
mariontr's Avatar
Well as things go, broke the thin bezel that is closest to the emergency brake handle, I'll see if I can glue back and in addition I broke one of the tabs that hold in the power switch towards the rear. Is it easy to replace that black part that holds the power switch?
Old 05-21-2020 | 01:09 PM
mariontr's Avatar
Has any member cut the retaining tabs off this thin bezel and used 2 sided tape to hold it down? Because I can see myself breaking it again since it is so fragile.
Kodebuster
11-05-2020 05:06 PM
tom2112
07-28-2015 09:12 AM
RED DOG
07-21-2015 08:58 AM
jtr2901
07-10-2015 07:33 PM
gtjl
07-08-2015 08:42 AM
