Traction control question.
Old 07-22-2009 | 09:40 PM
The Beep's Avatar
Default Traction control question.
Anyway to default the traction control off? Getting tired of pushing the button all the time.
Old 07-22-2009 | 10:34 PM
+fireamx's Avatar
Default Re: Traction control question.
Are you asking if there is a way to actually shut it completely off, instead of only partially "off".
Old 07-22-2009 | 10:39 PM
I have read in the past about pulling two fuses. Maybe someone else can help... (fuse 16 & 17)
Old 07-22-2009 | 11:38 PM
+fireamx's Avatar
Here's one.
https://www.crossfireforum.org/forum...58-esp-tc.html
Old 07-23-2009 | 12:12 PM
The Beep's Avatar
I'm sorry, let me clarify.
There's a button that turns the TC on and off. The default when you start the car is "ON". I would like it off. I don't need it on in Houston TX.
Old 07-23-2009 | 01:36 PM
+fireamx's Avatar
Gotcha, I really don't know how you would do it without reprograming the cars computer. Like James pointed out, pulling out those 2 fuses shuts it down completely. But some people have found that by doing so, their wing starts to act up, or their brake lights don't work etc.
I disconnected the middle wire on the traction control just ahead of the battery, and have had no ill effects by doing so, other than my anti-locks don't work (which is fine by me). But it seems that only works on the 04's, and a handful of 05's. I don't know if the automatics can get away with it either.
Old 07-23-2009 | 02:52 PM
If pushing the button tires you, you should get out and exercise.
Old 07-23-2009 | 02:55 PM
TX_xfire's Avatar
That's strange. The default on mine is whatever I have it set too when I turn the car off. I don't use it so it just stays off all the time.
Old 07-23-2009 | 08:13 PM
The Beep's Avatar
I work out every day...that button is still a pita.
Old 07-23-2009 | 08:14 PM
The Beep's Avatar
That would be great. I envy you.
Old 07-23-2009 | 10:55 PM
rcompart's Avatar
One of many projects I'm working on. I should have more info on it late next week.
Old 07-24-2009 | 07:15 AM
ppro's Avatar
Is there any way to remove the windshield? It's such a pain to keep clean and when the bugs hit I can never seem to get them completely wiped off...
And that pesky brake pedal... Always have to push it every time I want to stop. I gotta do something about that too...
Old 07-24-2009 | 08:37 AM
The Beep's Avatar
A hacksaw will resolve your brake pedal issue. As for the windshield? A large hammer will clean that up lickity split. Let me guess, your bumpers are in the way? Try a bridge pylon at 80mph. Fix em right up.
johnnycross413
03-04-2016 04:49 AM
2005 Ragtop
10-03-2015 03:01 PM
10-01-2015 01:42 AM
Charlesl
09-30-2015 10:46 PM
Billy22Bob
09-26-2015 10:16 PM
Quick Reply: Traction control question.
