Car makes a noice when I steer right
Old 05-27-2009 | 03:23 PM
FJMieses's Avatar
Default Car makes a noice when I steer right
Hi,
My car is making a light noise when I STEER RIGHT. I took it in to chrysler and they informed me that its my "Steering Damper". They wanted to charge my 1500 dollars to fix this. I dont know what to do. My extended warranty does not cover this. Will this become a huge issue if i dont get this repaired quickly and should i TAKE IT TO another shop to see whats wrong with it.
Thanks,
Frank
Old 05-27-2009 | 04:00 PM
MikeR's Avatar
Default Re: Car makes a noice when I steer right
You can buy the damper online for about $30 and install it in 15 minutes. Two bolts.
Look at this thread....
https://www.crossfireforum.org/forum...surprised.html
Old 05-27-2009 | 05:14 PM
blackcrossfire07's Avatar
Once in a while I hear a clunk. I have 53K miles and I am wondering if it would hurt to replace the steering damper. I noticed a huge price difference between the 2003 SLK part and the Crossfire part. Would the SLK part fit my car? I don't want to buy an aftermarket part.
Old 05-27-2009 | 05:50 PM
BORICAN's Avatar
Go ahead and change the damper because it's cheap and easy to do. I bought the SLK damper. Also check the wheel bearings because I made the mistake of thinking it was only the damper and it ended up costing me $1500 for the bearing, hub and labor.
Old 05-27-2009 | 05:58 PM
Would a 2003 SLK damper do the trick? I am going to order it and maybe swap it out in my next oil change.
BibaResto
11-07-2016 08:21 AM
Tommyj
U.K.
06-16-2015 07:21 AM
Ephr8a
06-04-2015 12:42 PM
ZX2 Nick
06-01-2015 12:57 PM
josh armstrong
05-30-2015 10:57 AM
Quick Reply: Car makes a noice when I steer right
