Little corner light bulb in headlight
Re: Little corner light bulb in headlight
Yes you can, Maxchicon helped me out with this. If you use a long pair of hemostats (sp?) or needle nose pliers you can get them out, and once out, put some bulb grease on them and they will go in a lot easier. Hope this helps, if you need more of an explantation, try using the search feature.....
xfClifford
27
11-10-2015 10:08 PM
