cruise control shifts
Old 02-17-2009 | 04:50 PM
lemm2005's Avatar
Default cruise control shifts
can you shift in cruise control sometimes ill set my cruise but ill be in 5th gear and they think why am I not in 6th. can you shift without taking it out of cruise or will that hurt my car. Iv always wondered but never wanted to try.
Thanks
Old 02-17-2009 | 04:53 PM
Default Re: cruis control shifts
Thanks
If you did it quickly, probably not a problem.
BUT>>>>>>>>>> WHY?
why would you want to?
That said, I have to admit, I've thought about doing it myself.
roadster with a stick
Old 02-17-2009 | 04:54 PM
itsky's Avatar
I used to have a six-speed. It will cut out the cruise control when you hit the clutch to shift. If you do not hit the breaks, the cruise control will kick back in with a second or two automatically.
Old 02-17-2009 | 04:59 PM
lemm2005's Avatar
well you know your driving on the road and set ur cruise on the highway in 5th gear and the speed limit changes here from like 55-70 on I74 so i go from like 60 cause theres mass cops to like 80 cause theres like none and just always thought do i really need to take cruise control off to go to 6th.
Old 02-17-2009 | 05:15 PM
No just change gear up, not down, I have done it on a few odd occasions, no problems that I could see. Changing down might be a bit different, never done that.
Old 02-17-2009 | 05:25 PM
With the high torque of this engine, there is little need to shift when going from 60 to 80. Just move the wand up or down.
Why would you need to shift?
roadster with a, like, stick
Old 02-17-2009 | 06:11 PM
Well, er like er save ur gas?
Old 02-17-2009 | 06:14 PM
danimal's Avatar
Default Re: cruise control shifts
You can shift up or down with the cruise control set......I do it all the time. There is a couple of seconds delay and it is really cool the way that it works. I'm not talking about dropping a couple of gears now....but if you need a little extra, go for it.
Another interesting thing is that it holds the set speed in memory. Most lose the speed setting if you turn it off.....not the Crossfire. Flip it off if you need to and go right back to the set speed with a quick pull of the lever.
Old 02-17-2009 | 06:48 PM
infared12's Avatar
I'm on the road alot..and I can say that I shift in cruise control all of the time.
Old 02-17-2009 | 11:31 PM
lemm2005's Avatar
i wanted to shift to basicly save gas theres no point in running at like 4-5k when u can do the same thing at 3k
Old 02-18-2009 | 06:12 AM
smfrycruzr's Avatar
I shift up and down while using the cruise control all the time. According to the manual, the cruise will only disingage while braking, or holding the clutch in for longer than 4 seconds, or by pushing the control stick forward.
johnnycross413
03-04-2016 04:49 AM
jimf
10-10-2015 10:22 AM
2005 Ragtop
10-03-2015 03:01 PM
Padgett
Southeast Forum
09-27-2015 09:37 AM
Billy22Bob
09-26-2015 10:16 PM
Quick Reply: cruise control shifts
