New sound system needed, need help with the panels...
Old 01-28-2009 | 08:54 AM
F117NH's Avatar
Question New sound system needed, need help with the panels...
Ok so I am replacing the Deck, two tweeters, forward 6 1/2s, maybe the 4x6s in the wall, and adding; an amp, cap and two subs... 12" or 10" not sure yet... but they will be the Shallow-mount kind, most likly Pioneer.
I have very Little experiance with new car intiors and dont want to hurt my XF that i just bought! I do knopw how to install everything and wire it all but the door and wall pannels are my first problem...
I bought a simple set of intior door pannel tools so i dont break any of the plastic clips and also a schematics(sp) manuel so i have an understanding of how to wire it all.
but please, where do i statr and with what tools?
videos and or play by play pic would help the most.
IF needed i have a 04 LTD.
thank you everyone
F117NH
Old 01-28-2009 | 09:52 AM
workindev's Avatar
Default Re: New sound system needed, need help with the panels...
Where are you planning on putting those subs?
Old 01-28-2009 | 10:13 AM
F117NH's Avatar
Next to the wheel well, right infront of the acsess hole for the rear lights. i plan on building a box to have the speeckers stand vertical with the front facing the middle of the compartment. that way i have access to the wire paths and if built rite i can still have a bit of storage room.
Old 01-28-2009 | 03:34 PM
07bluezx14's Avatar
How much money are you planning on spending? I have one twelve and it is pretty loud! I am going to warn you, you might end up addressing your electrical system. chris
Old 01-28-2009 | 03:44 PM
nox1s's Avatar
thank you everyone
F117NH
No offense, but you sound like you don't have a clue on what you're doing.. take your car to a good audio shop and have them do it.. but be prepared to spend $$$..
Old 01-28-2009 | 04:58 PM
faiz23's Avatar
Old 02-08-2009 | 09:19 PM
BlackCrossFire6spd's Avatar
I agree. I used to be a custom audio installer, and I installed my system in my car, so I have taken everything apart on this car. Believe it or not, it is not a dificult car to install a system in, but to get the most out of your equipment, it needs to be put in right, and this takes expierience and know-how.
Old 02-09-2009 | 09:48 AM
F117NH's Avatar
Cool Re: New sound system needed, need help with the panels...
Thank you for the consern but let me learn... whats wronge with pointing me in the right direction?
I have done this before and im not afraid of tackling this too.
I have found answers to my question and so for both of you, try sending the person asking for some help... some help?! I agree that sending them the advice of taking it to a person who does this thing for a living is good advice but also offer up a link of a place where they can do it there self...
why not!?
Old 02-09-2009 | 10:58 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Save yourself some time and frustation and just buy my set up. I currently have it removed to save weight during the drag racing season. Shoot me a PM if you want to discuss it.
https://www.crossfireforum.org/forum...ad.php?t=30215
Old 02-09-2009 | 11:06 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Oh...and to answer your question. With a quick search of "door panel removal" this PDF was found. This should serve as your play by play on how to do it.
Good luck on your install, these cars are actually pretty easy compaired to most and all topics have been covered. You can search for just about any question relating to the install and find the answer.
File Type: pdf
Old 02-10-2009 | 07:38 PM
why not!?
Fair enough. I'm a bit lazy, so I'm not going to type EVERYTHING that needs to be done, but i can give you my tips and tricks that I used. As for taking things apart, get the service manual and check other threads, I'm sure just about everything has been discussed here.
My system is as follows:
Alpine Deck
Audison 4ch amp bi-amped to
MBQuart 6.5" component speakers
-Crossovers are mounted in the rear speaker cavities
Audison Mono amp powering
2 10" MBQuart Subs in custom box with grille-cloth wrapped covers to conceal them
Alumapro 5-farad cap mounted under the passenger seat, under the floor
Dynamat completly covering the inner doorskin
Dynasorb panels mounted behind the speaker to the outer door skin
The only "permanant" modification that was made to the car was a small slit in a wire gromet under the hood. not a single harness was cut. Everything can be returned to factory and nobody would ever know there was a system in the car.
Getting power into the car is very easy. Connect your power wire to the battery terminal, make sure your in-line fuse is about 6" from the battery. Run the power wire into the compartment next to the battery by cutting a small slit into the bottom existing gromet. From there, it's a straight shot into the car through the back of the housing.
My amplifiers are mounted behind the seats to conceal them, and given my seating position and amp size, this was the perfect location.
I would greatly recommend running speaker wire directly from the amp to the door speakers. The gromets on the doors are HUGE, so wire can easily be run into them. THis way, you don't have to cut into the factory wiring, and can place the crossovers in the car and not the door.
My biggest tip is TAKE YOUR TIME. Don't rush through anything. There are more than enough factory channels for your wires to be placed in, but you have to take the car apart to get to them. I removed practically everything but the dash of the interior while performing my installation, but it was worth the extra effort. As for removing the seats, DO NOT remove the seats with the key in any position other than off. They are connected to the SRS system, so removing them while they are powered could throw an air-bag light, which only the dealer can reset. That also means don't turn the key on while the seats are removed.
Another tip, any harness that has a yellow connector is related to the SRS system. Take care with these.
Old 02-10-2009 | 09:34 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Alpine Deck
Post some photos of your set up. I would love to see it!
Old 02-10-2009 | 11:50 PM
shreker's Avatar
we have 4x6 in the back???????
Old 02-12-2009 | 12:46 PM
F117NH's Avatar
Talking Re: New sound system needed, need help with the panels...
great!
thank you for the support and help!
i look forward to getting all this done but ya its going to take time and so im not rushing anything!
I have the new 10" Pioneer shallow mount subs and have idea on putting them inside of the bumbper well right behind the tail lights. it looks like it may fit but havent taken the interior appart a secont time to put a sub in to see if indeed it does or doesnt fit. i would like to save what little room is in the trunk cuz i also own a 66' Mustang and it has a giant box with two 12"ers and the amp and cap in there and NOOO room for much else. Im all for saving space right now. i cant find anything on hiding the subs except for making a false floor, but even that limits storage space...
so if anyone has done something like this or has heard of it beeing done, please tall me about it!
and thx all!
ps, i think my tweeters are going out, havent put in the new deck yet (im hoping that will clear it up some) but do you guys have any sugjestions for new tweeters?
Old 02-12-2009 | 01:56 PM
SRT6nTulsa's Avatar
I can even fit my golf clubs back here...
Old 02-12-2009 | 01:58 PM
SRT6nTulsa's Avatar
I think he may be talking about the 4x6 grilles for the 7 inch subs. Am I right, F117NH?
Edited: The pair closest to the camera is the pair behind the seat. Both are 7 inch drivers.
Old 02-12-2009 | 02:05 PM
You should get a set of component speakers to replace the ones in the car now, not coaxial and add a tweeter. Component systems consist of a mid-range, tweeter and an advanced crossover network to seperate the highs and lows.
Old 02-12-2009 | 06:21 PM
danhaman's Avatar
I'm guessing most folks have run power down the pax side and Rca wires down the drivers side. How did you get the rca wires to the deck, did you route them over the peddles through the very small gap up by the top of the gas pedal, or is there another way to get to the other side of the car? I'm goingn to use a line output converter until I find a head unit that I like so I need to get to the passenger side foot area.
Thanks
Dh
Old 02-13-2009 | 08:13 AM
F117NH's Avatar
[QUOTE=SRT6nTulsa]I think he may be talking about the 4x6 grilles for the 7 inch subs. Am I right, F117NH?
Correct. I didnt know there were subs till i took it all apart.
plan on putting Pioneers in there too.
Old 02-13-2009 | 08:17 AM
F117NH's Avatar
[QUOTE=SRT6nTulsa]I can even fit my golf clubs back here...
Love the pics in yor gall. very good to look at what im in for!
but what was wrong with your wheel?
Quick Reply: New sound system needed, need help with the panels...
