crap headlights
crap headlights
Hi, everybody.
I have just bought my first crossfire coupe and I am mega impressed with it. It is certainly a headturner.
Has anybody out there had to change or upgrade the headlights or bulbs on dip beam due to them not projecting the light a useable distance. On unlit roads the headlights are so dim I have had to drive on full beam which is obviously not ideal.
Is there perhaps a legal upgrade bulb to fix this problem.
Thanks
Thanks
on
Re: crap headlights
May wanna check your headlamp adjustments. An easy way to do that is to pull up about six or eight feet away from a wall, garage door, etc. with your lights on. Are the beams approx. the same height and directly ahead of the car ? If not adjust or have a technician adjust them. Another common problem is that replacement bulbs are sometimes not seated properly when installed.
Just my Dos Centavos
crap headlights
I have owned many cars yet have never had an OEM headlight system that equalled the one in our Crossfires.
You know the saying "Crap in equals crap out"!
I have to agree that it is time to get the alignment of them checked. Also make certain all bulbs are burning. Mine light up the road extrememly well and yet I have never been "asked" to dim them because they were blinding an oncoming car.
There are more powerful bulbs available (not legal in all States perhaps) but I cannot understand the need provided yours are operational and adjusted properly.
Jim
Jim
Re: crap headlights
If you have a UK spec car you should also have a headlight adjustment in cockpit.
Re: crap headlights
Originally Posted by facpro
I was on a dark road the other night and noticed the lights seemed dim, no problem on bright. I also noticed that the exterior lens' are delaminating. does anyone know if they are expensive to replace?
Re: crap headlights
The Crossfire has projector head lights. If the bulb is not in the proper position the light output is terrible. I would check to see that the bulb is fully in postion and once in place that the metal clip is secure. I put HIDs in my crossfire and initially didn't have one bulb in exactly the right position. Once the bulb was seated correctly there was no problem.
jefecito (10-23-2022)
on
Re: crap headlights
Originally Posted by Kit Fox
I'm not quite sure that HIDs are actually legal depending on where you live. From what I read if a car ORIGINALLY came with HIDs they are legal but if you swap them out then its not legal.
That's how it is in Michigan as well... but what police officer is going to pull you over and ask you if your HID's came with your car? As long as you're running 4300k to 6000k you won't have any problems...
Re: crap headlights
On my 08 and the the dipped headlights are the best I've owned, however the fog lights and high beams are just average, so I'll probably tweak them to the Philips X-treme halogen bulbs once they become more available in the states.
If your lights are crap-o, besides the other suggestions, halogens lose 30-50% of their brightness towards the end of their life as the burned filament deposits residue inside the bulb.
Re: crap headlights
I am pleased with the headlights on the Crossfire, but when my highs and lows burn out, I am going to replace them with the Hoen xenonmatch Titanium bulbs. Will also replace the fog lights. Hoen I believe makes the best direct replacement bulbs. They are very high quality and last a couple of years. http://www.hoen-usa.com/index.htm
Re: crap headlights
Re: crap headlights
Originally Posted by blond xo
Silverstar ultras work well. I had some after market blueish lights for about a week then I swaped to the Silverstar ultras, they are the best you can get without going all out HID.
Re: crap headlights
Hi, everybody.
Thanks
Thanks
