The Stubborn Door
Old 12-21-2008 | 03:37 PM
BlazingSaddle's Avatar
Default Re: The Stubborn Door
Thanks, Dennis. That's exactly what I did. I had it printed out and handed it over to the service manager.
CrossfireFun, you should not have to live with that. The TSB says that in the long term, the problem might do some damage to the door itself.
Old 06-10-2013 | 11:38 PM
ThatSweetSRT6's Avatar
Going through this problem now...
TBS: 28-Jan-05 - 23-004-05 - Body - Window Glass Misaligned and or Contacts Roof
Is there a way to find more info on this TSB that has been previously posted in reply on this thread so I can show it to the Dealer or can this be a DIY project? anyone go through this issue?
Sorry for bumping the thread..
Old 06-10-2013 | 11:56 PM
SNAKEWOLF's Avatar
Down load free service manual and look at page 23-96 and 97
This will take care of window adjustment.
good luck
Old 06-10-2013 | 11:58 PM
good luck
Perfect, thank you! I will look into this. Any special tool needed that I have to use?
Old 06-11-2013 | 12:21 AM
SNAKEWOLF's Avatar
Go to Sticky How To's on Forum
First post click on Index of Problems
Look under Interior
Window adjustment
This will take care of all questions. Member is very accurate with his help.
Old 06-11-2013 | 10:32 AM
Try here CLICK, I adjusted a door for air leaks, and it is the same procedure.
Old 06-15-2013 | 12:27 PM
Spenzer4Hire's Avatar
For almost 2 years I struggled with my XFire and trucker's rut. The car would try and pull up out of the rut, throwing you into the next lane. It took a lot of concentration to keep it straight and made long trips mentally exhausting. I had the alignment checked, replaced the steering stabilizer, etc. but never found the cause.
Finally, I was due for new front tires and they made all the difference in the world. Now I only have to fight the rut when braking moderately hard coming up to an intersection, and I think that's pretty normal.
Also, I'm in Chicagoland and they recently repaved the section of 94 north of the 94/294 split. Whatever they've done with the asphalt makes it feel like the car is skating. It's sublte, but unnerving. It was less noticeable when I put my winter tires on. I've never felt that on any other road.
Old 06-29-2013 | 05:58 PM
Very cool, thank you!
Osusannah
02-12-2024 02:49 PM
Valk
07-12-2021 10:49 PM
Mackel
10-16-2015 10:03 AM
Billy22Bob
09-28-2015 09:08 PM
jaesa
09-07-2015 02:50 PM
Quick Reply: The Stubborn Door
