alarms when battery disconnected
Old 11-10-2008 | 03:56 PM
makeithappen's Avatar
Default Re: alarms when battery disconnected
the radio played for 45 min after the key was out? mine plays for 45 seconds at most haha. buttttt yeah i was proved wrong by myself. glove box set off the alarm but middle consule did not sorry
Old 11-10-2008 | 05:27 PM
tighed1's Avatar
Originally Posted by Kit Fox
I'll give you a hint, Barry Manilow was playing... LOL JK, naw, I was polishing my headlights and had music playing. Its funny that the radio works without the key but the brake lights dont.
Nor does the horn!!!
What's up with that???
Old 11-10-2008 | 07:36 PM
Kit Fox's Avatar
Ya I know right!! I forgot, how can the horn and brake lights not work with the key out, those are safety things!
Old 11-12-2008 | 06:47 AM
tighed1's Avatar
Originally Posted by tighed1
Also found out that the radio will play once the key is out. New one on me.
Oh I guess the radio doesn't work without the key. Just saw this in the maintenance manual...
"The audio system is standard factory-installed equipment. The system uses an ignition switched source of battery current so that the system will only operate when the ignition switch is in the ON/RUN or START positions."
Funny. Seems to work in my car with no key.
Old 11-22-2008 | 11:32 AM
jay bondrock's Avatar
Okay - back to the original topic.... Mystery solved! Don't remove your battery when the car doors are locked - it sets off the alarm big time.
I went back to get my battery the other day and, with the door unlocked, there was no issue.
No more Crossfire 'till April
Old 11-23-2008 | 08:16 PM
why not till april?
Old 11-24-2008 | 03:47 AM
FishHawk's Avatar
Had that trouble while disconnecting the battery to install an extra power outlet. Turned on/off??? the tow alarm. That stopped it from happening.
Old 11-24-2008 | 03:14 PM
Originally Posted by makeithappen
why not till april?
Winter storage. My house doesn't have a garage so for the winter I store the car in a long term storage facility. It's a bit of a drag 'cause I can't even go take an occasional look at it. Oh well... it's way cheaper than building a garage.
blackpepper
10-04-2017 06:09 AM
Mackel
10-16-2015 09:03 AM
o55ie18
10-05-2015 05:50 PM
tritongreen
09-18-2015 07:32 AM
Valk
09-17-2015 11:43 AM
Quick Reply: alarms when battery disconnected
