Headlight problems --bulb replacement
Searched found explanations but for some odd reason cannot seem to wrap my brain around the instructions, there appears to be a "hook" holding the wire clip down cannot figure how to move it and release the clip, help is appreciate
05 Coupe, right side light
TIA Terry
TIA Terry
on
Re: Headlight problems --bulb replacement
TIA Terry
TIA Terry
Push in on the wire clip, then bend it sideways to get out from under the hook thingy.
I hope this helps!
See? HELPFUL!
TIA Terry
TIA Terry
Here is where it started to get interesting. I could not get the top prongs into their respective holes. So I started reoving thins. First the pump thing. That did not help. So I decided to take out the entire light.
Reove the grill reomove the top allan screw holding the bumper. Popping out the side marker light. Turning the wheel to get int the opening under the lights. Removing the 2 screws under the headlights. Removing the top 2 screws.
What a PIta.
Success.
KDW4Him
18
09-01-2021 05:47 PM
mike28117
07-17-2015 01:59 PM
