AC Smells Horrible? please help!
Re: AC Smells Horrible? please help!
Originally Posted by blackcrossfire07
Don't start by taking the car apart. Don't remove the wipers. All you need to do is this.... after turning the car off with the AC switch still on, press the reset button. While your car if off, the AC will blow the excess air through the system and dry out all the condensation. Leave it on for a while and let it do its thing! Our cars are lucky we have that feature. I had no idea about it until I read about it on this forum.
Originally Posted by Peterk
So turn the car off and click the Reset button? Do you have to click the reset button back off after a certain amount of time? How does it it do this with the car turned off?
Originally Posted by crossfirefun
I would be worried where all that material came from to make that nest. Hope it didn't come from your car!
To get back onto the A/C smell... Most cars develop a smell from the condensation build up left in the system when the car is turned off after the A/C has been run. The bacteria love that environment, dark and wet. Here in California it is quite common since everyone uses their A/C a lot. The easiest way and most effective way to get rid of the cat pee smell is to get an anti mold & anti bacterial spray at the local auto parts house. It is designed specifically for car A/C smell and is found in the A/C section.
It is designed to be sprayed into the vents. Be sure to spray plenty of it into the each vent, but mainly into the vents by the glove box. It needs to drain down into the evaporator and kill the bacteria in the main area of the A/C box. Since the Crossfire has the extra feature of the system run when the key is off, use it. The smell of the anti-bacterial is strong too. Hit the recirculation button and walk away. Next time you use the A/C there will be the residue of the spray, but it's not bad. Do this once a year and everything will be peachy...or at least not cat peechy!!
Now go be Kuhl...
Now go be Kuhl...
Originally Posted by EpicDesyre
The "reset" button is actually the "recirulation" button on your AC Controls. Just shut off your X Fire like you normally do, then push the button. The reset indicator light will come on and your fan will come on at low speed and then automatically turn off after about 5 minutes. The function is to provide some climate control without running the engine (I am in sales and it's works well). It does help to dry the condensation from the system and helps to eliminate that annoying "Mercedes Benz" odor.
Blackktieguy
21
10-26-2015 12:32 AM
waldig
10-16-2015 11:39 PM
tritongreen
09-18-2015 07:32 AM
waldig
07-15-2015 02:05 PM
