can you beat this?
Re: can you beat this?
Originally Posted by MI1XFIRE
44.64 Liters = 11.787 U.S. Gallons
It works out to an unbeliveable 37.1 MPG (or 6.3l/100 km). That is if you filled it up to the top. Taken into account that the tank capacity is 60l, and you said the light had come on, it appears that it may not have been totally filled. Regardless 437 miles is great achievement. Congrats that will be very difficult to beat.
Sorry, I find it very, very hard to believe any Crossfire can attain 37.1 mpg at 70 mph. My Honda Civic does that.
Are you sure that your next door neighbor isn't sneeking over in the middle of the night and adding fuel to your tank with out you knowing it?
Or was your 437 mile trip actually 437 kilometers?
I think we could get that high of mileage in the crossfire if we tried hypermiling, i've been really thinking about giving this a try one night cutting the engine going down hills, no ac, windows up, taking turns that need to be taken at 25 at 50 because you never use the brakes all that crap.
Originally Posted by NEDRIDER
Well guys it IS in miles belive it or not,i just had to see for myself how much i could sqeeze out of a full tank driving it steady. who care,s if you dont belive, with juice over £5 a gallon at the moment i,v got to take it easy..
I'm just saying I don't believe that there is anyway a Crossfire is going to get 37 mpg simply by doing 70 mph and using the cruise control. Unless it's down hill all the way, with a tail wind.
As it's been suggested, you simply didn't fill the tank back up to the same level that you started with that's all.
fuel light was on when i filled up and just came back on tonight i put in 44.62 liter aint worked out mpg ..
Originally Posted by +fireamx
....I went back and noticed that Danimal mentioned that he travelled approximately the same distance, and it worked out to 30 mpg.
I think there was an earlier post somewhere on who had pumped the most gas on any given tank....15.035 was the furtherest I've ever pushed it after 415 miles.
Originally Posted by manisusmc
the crossfire fuel capacity is around 60 liters or 15.9 gallons, so if you filled up and your light was on i'm guessing either you didn't fill up all the way. even if the fuel light had just came on that should only be about 2 gallons max, normally they shoot for 50 miles left when the lights come on.
I usually never let my tank get that low. I've heard too many stories about fuel pumps getting too hot inside the fuel tanks and wearing out early because there is no gasoline surrounding them to keep them cool.
On the other hand, back in the 60's and 70's, guys were always installing electric fuel pumps on the "outside" of their tanks for better fuel delivery, but maybe the "air" cooling was enough.
I always thought not changing the fuel filter was the biggest reason electric fuel pumps failed.
www.CustomCrossfire.com
Originally Posted by ZAHANMA
owners manual says 15.9 gallon tank and 2 gallon reserve .... but no thanks, i dont even let mine get lower than 4ish gallons left....
Using your logic, there would be 4.1 gallons left when the light cames on....not approx. 2 gallons. It just doesn't add up or make any sense at all. Not that I really care one way or the other.....I would just hate for someone to get stranded because of something someone erroneously inferred....but then again, if they believed you, they would probably deserve it. Just my .02.
axnguyen
07-21-2015 11:41 AM
Fla_Xfire_SRT
06-29-2015 06:51 PM
