A ? on wheel width
Re: A ? on wheel width
Originally Posted by stevieb
Arc is right 10 inches at the rear.
Alot of people putting 275's on the rears now with no mods which is just under 11 inches
they will fit???????
Im getting new tires within 2 weeks
Originally Posted by fiberboats
Youre saying i can put 275's on rear with oem rims and no mods???
Yes they will fit.
My rims are not stock, but they are wider. Here are the details.
Rims: TSW
18x8.0 Nogaro Silver 5x112 Bolt pattern 32mm offset. - Front
19x9.5 Nogaro Silver 5x112 Bolt pattern 35mm offset. - Rear
Tires: Yokohama
Advan 245/35R18 - Front
Advan 295/30R19 - Rear
Now, that being said, I think you might be able to get a 10 inch wide rim in the back, but you'd better order just one and check it first. Also, I had to add a 4mm spacer in the rear to keep the tire from scrubbing the inner fender wall at full upward articulation.
Good luck!
Rims: TSW
Tires: Yokohama
Good luck!
