Overcoming blindspots??
Re: Overcoming blindspots??
Originally Posted by roadtrip
Any suggestions re: poor rear view visibility. Parking is a nightmare unless I pull in such that I can head out in forward. Parking at an angle, as at rest stops, is no better. Hey, thanks.
Practice Pilates until you can rotate you head 360 degrees like an owl.
I have more confidence in backing because I'm used to backing a bus blindly using just the three mirrors. You might work on that. Also you find yourself looking to see what's around your car more to find any problem obstacles before you get in and back it up.
One option is to install a new stereo head unit that allows a rearview camera to be hooked up to it. These usually are the more expensive DVD playing headunits. Most are also double din sized which cannot be installed in the Crossfire without reconfiguring the center console. However, JVC does have a single din DVD head unit that has a smallish 3.5" screen and Pioneer and Alpine have single din units that have a hidden LCD screens that pop out.
I have also seen a rearview mirror that has a small video screen that can also be hooked up to a rearview camera. Its big and bulky and would probably look like crap, especially with our small windshields.
Other than the mirrors mentioned in the previous post, thats about it.
Adjusting your side mirrors to cover the blind spots instead of looking down the side of your vehicle is the easiest solution and is how you should have your mirrors set anyway.
I still shoulder check when changing lanes, but I can tell at a glance in my mirrors if something is there.
Also, if you need to see the curb while parallel parking, just aim the side mirror down as far as it will go.
Hope that helps. Cheers!
I use the mirrors a lot and back out VERY SLOWLY if needed. Wait untill it's rainy, the windows are fogged and your in a crowded parking lot (better yet a busy school parking lot). I try to park so I can drive straight out.
I did seriously consider the roadster just for that reason. I really want 3 xfires, a coupe for the quiet, a roadster for summer and a SRT for stoplights.
Welcome to the fourms, Roadtrip. You're right about limited visibilty to the rear, but you'll get use to it and take measures to compensate. You just have to get the most out of your three mirrors and what you can see by turning your head.
This quote is good advice. My GMC Envoy does that automatically (set by computer in the car). You put the car in reverse and the words "curbview activated" comes up on the dash. That is real handy to see how far you are from the curb, but how often do we actually parallel park these days. Most all parking is in lots with a drive in and out, or an occasional back out of a space.
I'm more concerned with changing lanes at higher speeds not knowing if someone may be riding in my blind spot. I check the mirrors, give my head a quick turn, and then check the mirror again with a little neck stretching. The key is moving your body and head a little to make sure nothing is in your blind spot. Sitting straight up and relying totally on what you see in your mirrors will work most of the time. Do you feel lucky?
Bob
Bob
I set the side mirrors outwards, so that there is no overlapping areas between the windsheld mirror and side mirrors, which means maximizing the area that the mirrors can cover.
And as far as parking... the back end of the car is only 3 feet behind you.
Just get some convex mirrors like I did from an auto parts store (they cost under $5)...but get the ones that swivel/rotate/tilt (however you want to call it...as long as it can move). Then just stick it on your side view mirrors. Put it on the outward edge of the mirror for a wider coverage area.
I put mine more toward the inside (closest to me) because I thought it would look more sleek (which it does) and not mess up the look of my new baby. and since it swivels I can still adjust it to cover more area.
I used to be in an SUV with plenty of windows so this is quite different.
Havent figure out the other thousand blind spots yet....all I can say is just be patient. I yell "clear" before backing out
Originally Posted by P-DuBBs
Are they easy to install?
Piece of cake. They come with a strong double-sided tape that hold them in place solidly. Some members of the Lotus forum used black silicone, but their OEM mirrors are different. These mirrors really do enhance visibility and are well worth it.
Just how bad is it? The ones I drove definitely had their blindspots but are you really driving THAT blind? I can see where backing out would be a challenge but is it any worse than a minivan? I used to drive a school bus as well so it trained me to use miirrors too but I may have felt more secure than I should've when I did my test drives. How much would you say the Multivex mirrors improve the situation? I didn't check the prices but how much do they run? I have an arthritic neck so this may be a bigger issue than I thought.
I may need to reassess this coupe/roadster thing.
I always back into parking spaces.......I'd rather back into a space I cannot see very well where nothing is moving than back out in front of someone who's too busy dialing a cell phone.
Other than that.......I follow the Italian rule of driving:
"what's behind you................doesn't matter!"
I do like the idea of Multivex mirrors. I do wonder about the quality and clarity degrading over time; will they come loose; can they be removed without damaging the original glass/mirror; do they look clunky because of double thickness and tape; and will the heater part of the mirrors work through all of that stuff?
Also, I would think that the Roadster is better with the top down, but probably worse with the top up?
Originally Posted by Opticon
Bingo.
