More new owner questions
Old 02-21-2008 | 08:33 PM
klamathpro's Avatar
Default More new owner questions
It might just be different from what I'm used to and maybe it's just the way it is, but there seems to be a slight RPM hang between shifts. lt's like a half second lag before the rpms drop between shifts. My Viper and Stealth immediately start to drop once I pushed the clutch in and let off the gas, but the Xfire takes about half a second longer to wind down. Is this just the way they are?
Also, what is my car missing? I have a base model and there appears to be two mounting hooks for a rear hatch cover, like a retractable curtain. The Chrysler site shows it standard on the 2008 Limited, but was it included on the base models? I also have an empty hole in the foam on the right hand side under the trunk carpet. The left side has a tire repair can, but the right side is empty. Finally, what are the two hooks between the seats on the rear bulkhead for?
Thanks.
Old 02-21-2008 | 08:41 PM
robby363's Avatar
Default Re: More new owner questions
The empty hole is for the front license plate bracket that comes with the car. As far as the shifting mines a auto so I can't help there.
Old 02-21-2008 | 09:37 PM
NeverEnough's Avatar
The hooks are for a cargo cover, but it was extra cost dealer accessory until '08. None came with it. The pocket in the trunk is just that, a pocket. Some people have their CD changer there, I keep my "tools" there(Flashlight, Tire Guage, Rags, etc.) The 2 hooks between the seats are referred to as "Umbrella Hooks" I use them for Baseball Hats. As far as the RPM Hang, that is normal on Manual Crossfires. It's a sideeffect to the "Throttle by Wire" Electronic Throttle Body. A Sprint Booster will fix that "issue" if you continue to find it annoying. Do a Search for "Sprint Booster" and decide if you want one.
KDW4Him
18
09-01-2021 05:47 PM
toob
Crossfire Events and Meets
09-26-2015 02:22 PM
MAXIMUM
08-04-2015 11:04 PM
PNA
Car Shows
08-03-2015 08:22 AM
PNA
07-13-2015 11:40 AM
Quick Reply: More new owner questions
