TMPS valve caps???
Old 02-15-2008 | 05:40 PM
CoupeGirl's Avatar
Default TMPS valve caps???
Ok I have some new caps on my car and they are metel someone said it might interfere with the TMPS. But have been reading alot on the web and some say dont worry its mostly in snow areas that it gets stuckon the stem???
Does anyone use a different cap??? someone stole all mine at the dealers.....so bought these at walmart
Old 02-15-2008 | 05:45 PM
CoupeGirl's Avatar
Default Re: TMPS valve caps???
Com on guys I am stressing here
Old 02-15-2008 | 05:56 PM
vaiodude's Avatar
the stock caps are metal...those caps should be fine
Old 02-15-2008 | 05:59 PM
Sidez's Avatar
here is what I have...
http://cgi.ebay.com/ebaymotors/JEWEL...em320217087650
Old 02-15-2008 | 06:49 PM
CoupeGirl's Avatar
I really need to know they will work,
Old 02-15-2008 | 07:32 PM
Yes! The TMPS doesn't care what metal or plastic the valve caps are. They are reading from inside the tire.
Old 02-15-2008 | 07:35 PM
CrossfireLTD's Avatar
Cool Re: TMPS valve caps???
Agreed....they will work and not cause a malfunction.
Old 02-15-2008 | 08:02 PM
CoupeGirl's Avatar
thanks guys dont want another trip to the shop;9
Old 02-15-2008 | 11:31 PM
DanielNTX's Avatar
I've had Spincaps (Security Valve Caps) for months and no problems. Here's the spincaps URL: http://spincaps.com/
Old 02-16-2008 | 05:40 AM
Steve Hellums's Avatar
The OEM cap's are aluminum and so are the threaded part of the valve stem. I had lost one on my car and had just put a chrome one on that I had laying around. When I made a trip to the tire shop to have my 285"s put on the rear the tire guy noticed it and said I should not be running it on there. When I asked him why, he told me that the aluminum and the chromed cap that I had put on could have a reaction to each other and cause corrosion. He said the main problem was that if they did get corroded together that when you tried to unscrew the cap that it could break loose the TMP valve stem seal, then you would have to break down the tire on the wheel to retighten it. I have worked in many different fields in my life and I do have some knowledge of metals and what he said is true, so if you want to run something other than the OEM aluminum caps (except plastic), I would use a little antisieze.
Old 02-16-2008 | 06:00 AM
danimal's Avatar
I have used spincaps as well for over 2 years now with no problem at all. As Steve said, I also use a little antiseize compound occasionally when checking the air. If you check the air often enough, seizing will not occur, but I like the insurance.
The most important thing in buying valve stem caps for wheels with TPMS, make sure that they have the little rubber o-ring in them to seal out moisture.
Old 02-16-2008 | 06:06 AM
incognito's Avatar
Like what Steve and Danimal said.
Old 02-16-2008 | 06:22 AM
crossfirefrank's Avatar
I guess if your really worried about it and want to know for sure you could let some air out of the tire to trigger the TMPS light and just reinstall your cap and see if it stays on.
Old 02-16-2008 | 06:41 AM
Stogey's Avatar
I agree with Frank, easy way to test it ! I've got chrome caps on mine and had never really thought about "signal strength" til now !
Just my Dos Centavos !
Make sure ya got a tire pump handy, tho !!!
Old 02-16-2008 | 07:20 AM
CoupeGirl's Avatar
I have read alot yesterday on the web about, most places that snow, and ice and salt on the street causes most problems.... I will watch them to make sure.....
Old 02-16-2008 | 08:04 AM
maxxm's Avatar
Insurance is good. Is there any particular antiseize compound that you recommend for use with the spincaps? I have a set but have been wary of using them for the reason discussed in this thread. Thanks.
Old 02-16-2008 | 08:16 AM
Stogey's Avatar
You can buy a small tube of Anti-Seize at any of your local Auto Parts. It won't take much ! Any anti-seize should be fine for this application
Just My Dos Centavos !
Old 02-16-2008 | 08:28 AM
danimal's Avatar
Exactly. I picked up a couple of tubes of 'Never-Seez Anti-Seize & Lubricating Compound' but I don't remember which auto parts place that I got it from. As Stogey said....any brand will do the trick. I just apply a light coat with a q-tip every 3-4 months.
Old 02-16-2008 | 08:31 AM
maxxm's Avatar
Thanks guys! That's good advice. Love this forum!
Old 02-16-2008 | 11:11 AM
cgocifer's Avatar
I mean really, are you seriously worried about valve stem caps and the TPMS? What did people do without TPMS? I'll tell ya! They went out with a tire gauge and took 5 minutes to check their tires!!
Car gadgets are making people lazy!!
The caps on my car were plastic when I bought it. I put aluminum ones on it.
