Do you get lots of rock chips? Poor paint quality?
Re: Do you get lots of rock chips? Poor paint quality?
Originally Posted by blackberry
Ribs out, interesting... That does sound the way to go, did you cover just the top of the hood or lower?
Originally Posted by cgocifer
First of all, bras, other than clear, are horrible for your car. Second, many newer cars have the paint chip problem. The Infiniti forum I used to belong to discussed the same thing, but much worse!!! A few years ago, higher environmental restrictions called for the elimination of a certain compound used in paint as a hardener. Since then, manufacturers have had to use much softer paint formulas.
Originally Posted by RPM
The paint does seem to be very soft on these cars (as are the windshields).
Seems I read that MB uses a much softer paint than other makers.
Now have 2006 Toyota RAV4, same thing.
The culprit is newer technology used on tires creates better traction, however all those sipes pick up a lot of the grit the spread on roads and makes same like car in front is shooting you with bullets, Crossfire stored for winter and will come out once roads have been cleaned from crap in spring.
