Tire pressure monitor???
Re: Tire pressure monitor???
Originally Posted by Goldwing
Starting to search the forum for tire pressure monitor issues. My warning light came on during the start of a long road trip. I checked the tires and the fronts were 33, rears 35. A few hundred miles later I stopped at a Walmart and had them all filled cold to 35. Light has not gone out.
Any suggestions on what to do to fix the problem? Car is out of warranty and I don't feel like spending $100 deductible that's on my extended warranty....yet.
Have you folks checked the batteries on your sensors?
Also, if you can get a free OBD-II/CAN BUS scanner, you should be able to figure out which sensor is giving you problems. Unfortunately, our cars simply have a single display for all four tires (unlike the Dodge info system, which shows all four simultaneously on a display.)
Just from my own personal experience, my Tire pressure kept coming on and it ending up being a slight crack in the rim. I constantly had to put in the tire and the dealership couldn't figure it out. It took two dealerships and tire shop to finally nail down the problem.
tritongreen
09-18-2015 07:32 AM
