How quiet at idle is your cf?
Re: How quiet at idle is your cf?
Originally Posted by woody
Just some additional information; the sound of electromagnetic injectors can sometimes be mistaken for lifter/valve gear noise, they do make quite a sharp 'click, click, click' sound at idle. You will notice it much more with the with the bonnet up and the engine cover removed when you are working on it.
I gotta check this stuff out otherwise I never know for sure...
Cgocifer,
Could the squeaking sound be coming from your suspension? I can hear mine squeak and groan if I stop hard and bob the front or rear ends.
My engine idles quietly but does occasionally give a very slight shake. Now if you want to experience real stumbling and loping, get into a single engine general aviation plane and run the engine at idle - especially if said engine is cold.
I just got my car and there are no abnormal sounds emitting from the engine. It sounds a little like our old 93 Maxima engine. i must admit you guys are scaring me!
I have an 03 Nissan Altima 3.5 with the equivalent of 80,000 miles and it runs smooth as silk. With the mods I have, it goes like stink.. Its downside being some torque steer and the complaints from my wife when i walk on it.
My Crossfire isnt insurable yet so its stting in the garage taunting me.
I have the normal whirring/ticking. I can also feel that slight stumble you mentioned. Probably the quality of the gas we use (winter gas here). With the motor turning at a mear 500rpm (or whatever it is) the slightest inconsistancy will be noticeable. Don't know if I'd class it as a misfire though. It seems much more subtle.
Danyuhl
11-02-2019 05:18 PM
09-13-2015 02:12 AM
