Traction Control Test
Re: Traction Control Test
Never had that issue myself. Acceleration while moving only seems strange if you manually downshift and 'punch it' and then the transmission tries to downshift again. You learn to let the transmission do the work in those cases or you learn not to really 'punch it' and ease down on the accelerator after YOU downshift to the proper gear. This is much smoother and you can still aggressively push the pedal down without forcing the transmission to try and downshift.
Sounds like you may need to do an accelerator reset.
Traction Control Test, Yaaaaaaa....about that..took a 90 degreeish turn off the main road tonight after I told my teenage daughter to hang on and punched it in 2nd. Prolly best described as a slightly controlled skid. Heh. It recovered easy enough but definately caught me by surprise after speed turning with the TC on. Note to self.... Leave the TC on! 2004 silver blue 6spd coupe. Annnd......Loving it!
johnnycross413
03-04-2016 04:49 AM
2005 Ragtop
10-03-2015 03:01 PM
