Crossfire Cigar humidor
Re: Crossfire Cigar humidor Question???
I have a humidor, it was a gift from my wife. The lighter (Prometheus) and cutter (Xikar) are first rate. The only issue I am having is with the humidification material that you wet with solution.
I had to take the two magnets out of the material as it is falling apart.
Does anyone have any suggestions for replacing the green material?
Thanks,
Red
Thanks,
Red
get one of those tubs filled with that gel that holds water, from any good cigar shop. buy a glass tubed cigar (with a plastic cap) this means it will probably be a crappy cigar. fill the tube with the gel stuff. drill several holes in the center top not to close to the edges. put a piece of sponge in the end so the gel wont leak out while on its side, works great. refill with water as needed. distilled water only or you might get mold in the jell.
next
next
Originally Posted by 62thunderbird
Those are getting harder to find. I think having one would be neat. How many here have them (and use them)?
Originally Posted by tayloratkins100
I finally found a humdior on Ebay! I have been checking fairly regularly for about a year, and just when I had given up... one was available with a buy it now option. It should be arriving today!
Thanks.
About Crossfire humidors ... it's tough to set up search parameters since one of the popular cigar lighters is called "Crossfire".
And anybody who's bidding on popular items should use a bid monitor ... there's a page full of them here ... any of them should do.
rayth
41
07-31-2019 04:02 PM
RED DOG
-C-I-C-C-I Discussion
25
07-26-2015 07:25 AM
MiamiTVR
07-14-2015 01:26 PM
ultrajim49
17
06-27-2015 12:20 AM
