Need help for wiring to Infinity amp socket
I have 2007 crossfire with custom radio. I have replaced the Infinity amp due to the amp got wet and out of order.
It sound a short time, but it got no sound by touching the wires.
I found that the orange/yellow color two wire were out of amp connector socket.
I would like to know how to connect the two wires to the corresponding socket pin.
If you have wiring diagram for the amp, it will be very helpful.
Thank you.
two wires were out of Infinity amplifier socket
Thank you.
Re: Need help for wiring to Infinity amp socket
Thank you.
Thank you.
Thank you.
Thank you.
ymatt, I see at least two sets of wires cut in that picture, looks like someone has been doing some modifying here. Suffice to say it might be slightly harder to trace/rewire at least those two, and also replacing those two connectors you posted about being out of the connector (the connector you referenced). Good luck!
atd
11-15-2017 11:06 AM
okilydokily53
07-02-2008 07:21 PM
