program
program
I wonder how difficult it would be to have these programmed to match a vehicle?
https://www.ebay.com/itm/Genuine-Mop...A/223576786595
Re: program
To do it requires the Chrysler DRBIII or Starscan scanner, depending on what year car you have, to copy the secret "handshake' code from the PCM and write it into the new blank SKREEM.
Here is a relevant related thread: https://www.crossfireforum.org/forum...-module-2.html
cojoman had significant problems with a Chrysler dealer not being able to do this. I don't think he was ever able to get his car running.
Re: program
I contacted them about programming (SKREEM and FOB are VIN Specific) and was advised that programming is be conducted by the local dealer.
I think most of us know that local dealers can’t do anything remotely close to programming. Or service or whatever on our cars.
Caution in on buying this item. If you cannot have it programmed to your VIN it will be a nice door stopper.
on
Re: program
"The SKREEM retains in memory the ID numbers of any ignition key transponder that is programmed into it. For added system security each SKREEM is programmed with a unique secret key code. This code is stored in memory, sent over the CAN data bus to the PCM, and is encoded to the transponder of every ignition key that is programmed into the SKREEM. In the event that a SKREEM replacement is required, the secret key code can be transferred to the new SKREEM from the PCM using the DRB III scan tool and the ignition key system replacement programming procedure. Proper completion of the ignition key system initialization will allow the existing ignition keys to be programmed into the new SKREEM so that new keys will not be required. In the event that the original secret key code cannot be recovered, SKREEM replacement will also require new ignition keys. The DRB III scan tool will alert the technician during the key reprogramming procedure if new ignition keys are required."
Re: program
I purchased one but still have to check on the programming. It's too bad none of the Crossfire Technicians, that understand and do this process, are not on this forum to share their knowledge. This should be old technology by now. I would honestly like to wait for programming until I need it and save it in case I acquire another Crossfire with issues. I would also like to be able to have one of the keys programmed now for a backup?
Re: program
I purchased a couple sets, hopefully to keep my Crossfires running when SKREEMS become no longer available. Or get another one running if both keys went missing. Maybe they will just turn out to be expensive door stops...at this point IDK...but I would think there was an avenue open to make these sets work in any car (with programming) which is why they were packaged by Mopar with two keys and a door lock, ign lock, and glove box lock, and SKREEM. ???
ZERACER if you find out anything about this, I'm all ears!
on
Re: program
And it IS suspicious:, " In the event that the original secret key code cannot be recovered, SKREEM replacement will also require new ignition keys. "
We know that is wrong, when you order a SKREEM, the manufacturer programs it with the code associated with the VIN from the manufacturing records.
Re: program
Why, year after year, did they put the "new" SKREEM and KEY programming instructions in their service manuals?
Having the option to get a SKREEM already programmed to match a car, for a plug and play installation, does not preclude the option to get a blank SKREEM and program it using the factory supplied tool.
on
Re: program
Just be careful - if you order a SKREEM from Rob at Needswings, it will work and be right. THAT much I know.
Go ahead, SHOW me someone who has made a SKREEM work OTHER than one from a dealer or Rob.
I'm not saying I WANT it to be this way, I'm saying that it IS this way, as far as I know. I'd love it if the "SKREEM" issue could be fixed easier, hell, I may have a dead SKREEM some day myself.
Re: program
Look, if you want to, order one and see what happens. I'm just reporting what I've gathered from others.
Surely a nation that can go from putting a man on the moon to electing The Donald can do anything one would think.
I have The Technicians for the DRB III Crossfire Diagnostics. Maybe I should read it.
Re: program
on
Re: program
(That won't be easy, if the car is 1200 miles from you - so I know that we may end up waiting a long time...............)
