Familiar Starting Problem
As experienced by other members, my 2006 Ltd Convertible stopped dead (as if out of gas)even though there was fuel. The dealer went through the "sell parts" routine and replaced the fuel sending unit (didn't help), then replaced the engine control module (sensor) and the car runs fine but now the gas gauge doesn't work. The dealer wants to replace the dashboard cluster. I said no. I don't want to have the dashboard torn apart just to pay for another expensive part.
Here are my guesses but, I will greatly appreciate any input or suggestions:
1) Maybe the programming was not done right when they did the work on the fuel system.
2) Other posts have said installing updated parts in the fuel system causes issues unless you replace fuel pump, fuel lines, etc.
3) Dealer says the module is sending signal to the gauge, but he gauge is not receiving -- but I know from other posts that Crossfire gas gauge problems are not uncommon, maybe it's unrelated to the work they've done.
Thanks for any help.
Chili
Chili
Re: Familiar Starting Problem
A scan of the bill may tell if this is true. Where the word sensor came from could be the CPS. A confusing account of what was fixed does not help. Dealers like to baffle people and hike the bill up and up.
Update
Reading all this again has confused me even more. I cannot see where his items 1 and. 2 make any sense. Item 3 is hardly worth replacing the dash for. My advice is to go somewhere else.
I give up.
Chili
Chili
Thanks for all the input, I really appreciate it.
To clarify a bit -- the dealer first replaced the fuel level unit which is part #5127430AA and a fuel pump seal #5101733AA (they said they were bad, but it did not help the car to start), then replaced what they call a relay (I call it an engine control module) Part #5099007AA and the car started and runs but the gas gauge does not work.
In a 2006 with 15,000 miles (I live in Naples FL. where people often live part of the year and let cars sit for long periods) the fuel pump seal could have been bad. But it seems to me from what I've read on this forum the problem may have been the relay (maybe a solder point) to begin with. I still think I should be able to get a gas gauge to work without tearing up the dashboard. Anyone disagree?
Thanks again,
Greg
Thanks again,
Greg
Thanks again,
Greg
Thanks again,
Greg
Why the sending unit was replaced is a mystery and if they replaced it and the gauge worked before it should work now.
I think that the dealer figures if you can live part time in Naples then you can afford to help him put his kids through Yale.
Get them to fix the connections to the sending unit or what ever it was they did. They would have a hard time explaining this to someone in the know.
The RCM could have been probably fixed by someone handy with a soldering iron for nothing. I guess you paid around $300 for a new one, plus labor and taxes.
I checked the numbers and they did replace the fuel level sending unit, the other parts were the gasket for the sending unit and the Relay Control Module (RCM).
I may be in Fl in February, taking my daughter and wife to Universal for a Harry Potter fix.
Hopefully not, the problem was known to SLK owners before the Crossfire problem came on the scene. The fix to the three solder connections was known and was copied.
Mercedes would have been blind not to have picked up on the problem, so I assume the later ones have been fixed.
See if you get a parts warranty, and as for Clariton, I used to know someone on Paine Hill, and would go snowmobiling and dirt biking there.
Forum contributors I am sorry to say the saga continues. My fuel gauge still does not work. I had an independent shop test the fuel sending unit that the Chrysler dealer put in and they confirmed the part is good. They could not check the programming because Chrysler software is needed for that so I went back to the dealer and they rechecked all their work INCLUDING the programming (at no cost)and said everything was done right. They want to replace the dashboard cluster.
The gauge worked before the car stopped dead. The replacement of the fuel level sending unit and the engine control module have it running great except for the gauge. The dealer wants to replace the dashboard cluster unit and I said no! That part is expensive, hard to find and all of the other gauges work. Surely there is simpler answer.
HELP!! The car is terrific cosmetically, has only 17,000 miles and is fun to drive. I don't want to give up on it unless it's a money pit.
Chili
Chili
Chili
Chili
Chili
Chili
Is it possible that the plugs on the fuel sender are on the wrong way? That makes some sense to me.
One plug is for the level and another for the pressure.
Thanks Aero -- I'll have the plugs checked. Just to clarify, what I wrote are not my statements. They are what I'ver read on line or what have been suggested by others much more mechanically inclined than me. I am happy to eliminate any possibility that is not really a possibility.
Who is "Aero" ?
Don't see any user name like that on this thread ......
are you referring to onehundred80 ?
aka 180
aka Dave
aka King of the Frozen North
aka the Cranky Canuk
aka the Caliph of Calendon
aka the Oracle of Ontario
aka 180
aka Dave
