Found good price on the Kenwood Kmr-D562bt
I am about to pull the trigger on a new head unit and stereo upgrade and after reading here for hours I decided to go with the marine Kenwood with Bluetooth so many here have bought. I found a pretty good price for the pieces. You can save a bit from Crutchfield if you don't mind ordering the pieces separate.
Kmr-D562bt $117.55 shipped Kenwood Kmr-D562bt Cd Stereo With Bluetooth
Scosche harness adapter $4.98 shipped Amazon.com: Buying Choices: Scosche VW01B Power/Speaker Connector for 1986-Up Volkswagen
Metra antennae adapter $4.39 shipped Amazon.com: Buying Choices: Metra 40-EU10 VW /BMW/Euro Car to Male Motorola Vehicle Antenna Adapter
Infinity Reference 6032cf door speakers (pair) $47.16 shipped Amazon.com: Buying Choices: Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance 2-Way Speakers (Pair)
Pyle PLPW6D 6-Inch subwoofer (2) $33.90 shipped Amazon.com: Buying Choices: Pyle PLPW6D 6-Inch 600 Watt Dual 4 Ohm Subwoofer
Total shipped $$207.98
Re: Found good price on the Kenwood Kmr-D562bt
Travish, good investigative work on the Kenwood. I too found it less expensive elsewhere other then Crutchfield, but found Crutchfield lifetime tech support worth the extra $ that I paid. I have contacted them at least 3 times for support mostly because I forget functionality after the CF sits in the garage waiting for outside temps to rise. Also, there is some confusion regarding the antenna adapter for the install. Crutchfield stated that one type was required while Rudy Compart stated that a different adapter was required. Rudy did the install. Guess who was correct- Rudy! Crutchfield sent me 2 antenna adapters (only charged for one) after several conversations about which adapter was correct. I can't recall the details/difference of the 2 adapters, maybe one was a power adapter while the other was simply a conversion adapter, can't exactly recall. I guess you will find out soon enough. One thing I have found, every time service or mods are needed on my CF, much discussion occurs as to proper procedure. The forum is a tremendous resource for information! Rudy Compart is a tremendous resource for the forum as well as many very experienced CF owners. Enjoy the Kenwood!
I installed the KMR-D558BT about a year and a half ago, and love it. Did pyle subs and they sound better that thought. Looks like you have done the research on forum and found what you need, GL post your pics when done, and let forum know if u need help.
