Radio / stereo gremlins
Old 11-09-2013 | 09:23 AM
JONMAZARICOS's Avatar
Default Radio / stereo gremlins
Hi, my standard factory radio is jammed. I use one of those adapters that you plug into the lighter, find a blank frequency and play music from a pre programmed chip. Somehow the radio plays the music from the adapter but unable to change volume or frequency or turn system of or on. Its simply stuck playing what music I have, if I remove the adapter it sticks on that frequency but still unable to turn on or off.
Aaaaaghhhh! its driving me bonkers!!!!!! Any ideas?????
Someone please HELP
Old 11-10-2013 | 11:22 AM
Default Re: Radio / stereo gremlins
Well, somehow everything is back to normal. After assessing all the options decided to take another look at the fuses and even though they looked in perfect working order, pulled them out and re-installed them and Whaaaam! I have lift off.
Old 02-12-2014 | 12:52 PM
B1gfun's Avatar
Mine was doing the same thing. I pulled the fuse and all was well again. Glad it worked for you too!
Old 02-12-2014 | 01:49 PM
I'm not surprised that worked, you reset the microprocessor with a power-down and power-up cycle.
I've had to do it once in the past three years/65,000 miles when mine would not turn on.
aerobluehal1
Canada
19
10-13-2018 09:47 AM
Sterling57
04-11-2016 06:11 PM
smokey847
11-12-2015 11:54 PM
brandoni
09-30-2015 07:48 PM
Selbyl
09-26-2015 04:15 AM
Quick Reply: Radio / stereo gremlins
