Factory Alarm Chirp! Solved! Read!!!
  #61 (permalink)
Old 06-14-2008 | 11:10 AM
maxcichon's Avatar
Default Re: Factory Alarm Chirp! Solved! Read!!!
I found when detailing the engine compartment that my cowl cover is CRACKED! When Karrmann installed it, the cable bundle under it in the center was not flat enough and when they tightened the screws, it put a bit of curse on it. Over 3 years time, the PVC gave up and cracked about 6" long from one of the center screws.
Under warranty, and at the same time, they will replace the alarm with the new one. Panic button doesn't work. Sounds like it's under water when the siren is forced.
AND the TPMS sensors I bought on eBay have to be reset.
All next weekend, hopefully after I get my new rotors installed.
It's nice to be on good terms with a dealer that has good/trustworthy xFire techs!
  #62 (permalink)
Old 06-20-2008 | 05:33 PM
tom2112's Avatar
She can ride with me ;)
Wow! What a COLLOSSAL pain in the a$$ that thing was to change out!!!
$70 for the part and $40 for the security torx set I had to buy to put it on. Not to mention the retarded bolt that held the device in place. Why would they weld the nut in place? If anything, weld the bolt in place, since you can hardly get at the bolt without removing your intake! Ugh. I was going to take photos and document the process for the forum, but I got so pissed I forgot the camera. Oh well. I would think it would be worth the $40 to pay someone to swap it out for you.
But, at least it is done AND I have beeps now. Woohoo!!
  #63 (permalink)
Old 06-20-2008 | 05:41 PM
maxcichon's Avatar
Exclamation Re: Factory Alarm Chirp! Solved! Read!!!
New cowl grille and an alarm that lets me know its working...priceless.
And they reset the TPMS sensors for my new tires/rims.
I'm happy.
Tomorrow-I install my new rotors.
Film at 11...
  #64 (permalink)
Old 06-20-2008 | 07:14 PM
NJCrossfire05's Avatar
12mm to remove nuts off of wipers
T20 torx bit to remove the crowl
4” gear puller from pep boys $24.00 to remove wiper arms
14mm to remove bolt of alarm housing from car.
TX30 security bit to remove siren from housing.
Lessons learned: The bolt to remove the siren housing is pictured below with the socket wrench with the red handle. It is on the exterior of the crowl.
#1 Remove wiper arms using 12mm socket and gear puller.
#2 Remove crowl using a T20 torx (star bit). 7 torx screws.
#3 Remove the siren housing from the car first.
#4 Remove siren from housing using the TX30 security bit.
#5 Turn on car to deactivate alarm. (I blew out my ear drums)
#6 Carefully remove wire from siren do not use a screw driver. I did and broke a retention clip.
#7 Plug in new siren and shut off car to avoid a second degree burn to your elbow.
I was worried about attaching the wiper arms but they just pop on and tighten up with the 12mm nut. No sweat, however you must use a gear puller to remove them! Do not try to just pull them off it won’t work.
All in all it took about an hour with the right tools and I like the tone. I will try and figure out a way to post the tone here soon.
Also read Iamfink2 post and clean out your drains!
  #65 (permalink)
Old 06-20-2008 | 07:31 PM
brain_26's Avatar
Do you have a name brand, or price info on the TX30 security bit? Your information has help a lot, and thanks for posting it as well.
  #66 (permalink)
Old 06-20-2008 | 08:24 PM
corfire's Avatar
Talking Re: Factory Alarm Chirp! Solved! Read!!!
It sounds expensive and complicated. Why not just do my simple mod for less than $5.00?
https://www.crossfireforum.org/forum...ad.php?t=23009
  #67 (permalink)
Old 06-20-2008 | 08:25 PM
tom2112's Avatar
It isn't a T30, it's a T40!!
Be absolutely sure that it's the tamper-proof version with the hole in the torx tip, or it won't do you any good.
I bought mine as a part of a set of security torx bit/sockets from Sears. They're Craftsman, and the set was $40:
http://www.sears.com/shc/s/p_10153_1...2614000P?mv=rr
Or you can order just the T40 bit from Sears for $4:
http://www.sears.com/shc/s/p_10153_12605_00992376000P
Here's a nice set of security/tamper-proof bits, including the T40 for only $15 (wish Sears would have had this in stock!):
http://www.sears.com/shc/s/p_10153_1...0836000P?mv=rr
And, by the way, there's no R in cowl.
  #68 (permalink)
Old 06-20-2008 | 08:27 PM
tom2112's Avatar
I already did that, and I didn't really like the results. Plus this way it's factory, and covered by warranty.
  #69 (permalink)
Old 07-17-2008 | 07:34 PM
The little Radio Shack buzzer being discussed at https://www.crossfireforum.org/forum...281#post216281 is actually very quiet - I just installed it in my car a few minutes ago. $3.78 tax included. Stupid simple installation, too.
OK everyone here is the official sound clip from the radio shack device
Turn up your sound.....
http://www.youtube.com/watch?v=URCocPE2Mpg
  #70 (permalink)
Old 07-18-2008 | 03:29 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Thank you for taking the time to put this one to rest......
  #71 (permalink)
Old 08-12-2008 | 08:38 PM
tollefsrud_77's Avatar
Very good information. I will defiently do this in the future. Thank you very much.
  #72 (permalink)
Old 08-13-2008 | 07:03 PM
amcordo's Avatar
Time to put the noise to rest.
Will someone who has installed the new alarm please say which one of these it sounds most similar to?
1) http://www.youtube.com/watch?v=PYTgC97wPdQ
2) http://www.youtube.com/watch?v=R29JgE6cviY
3) http://www.youtube.com/watch?v=jpvuRLCRQGY
4) http://www.youtube.com/watch?v=vREykA-7tFw
5) http://www.youtube.com/watch?v=KL3LGTGP0IE
6) http://www.youtube.com/watch?v=zLxXSZtzzdk
  #73 (permalink)
Old 08-13-2008 | 07:05 PM
maxcichon's Avatar
#3 for the OEM upgrade.
  #74 (permalink)
Old 08-13-2008 | 07:17 PM
amcordo's Avatar
Thanks Maxcichon!
  #75 (permalink)
Old 08-14-2008 | 07:12 AM
Mike-in-Orange's Avatar
Originally Posted by amcordo
That sounds exactly like the $2.49 Radio Shack buzzer I installed in my car in about 10 minutes. Not so sure I'd buy a $70 part and $40 in tools to achieve the same nonessential result.
  #76 (permalink)
Old 08-14-2008 | 08:50 AM
corfire's Avatar
Red face Re: Factory Alarm Chirp! Solved! Read!!!
Once again, I'll attach a link to the instructions on installing the Radio Shack tone buzzer that gives results that are about the same for less than 5 bucks.
  #77 (permalink)
Old 08-14-2008 | 08:51 AM
corfire's Avatar
  #78 (permalink)
Old 08-25-2008 | 06:10 PM
BlackCrossFire6spd's Avatar
I've been away from the forums for a while, so I have not seen the questions building up. Unfortunatly, when I installed the siren, i did not have the time to take pictures of the process. They made the siren dificult to remove because it is a SECURITY device. if it was easily accessible, it would be useless because it could more easily be disabled.
As for the wiper removal, it is actually very easy. After unbolting the 12mm, use a set of adjustable pliers to remove the wiper. put the fixed end upward and underneeth the wiper arm, and adjust the plier to close the moveable jaw on the bolt. Give it a squeeze and it should come loose. Remember where the wiper was positioned before you remove it because there are no indicators for the correct position of the wiper.
  #79 (permalink)
Old 10-04-2008 | 07:40 PM
SRT6nTulsa's Avatar
Another confirmation: To fix the lack of an alarm beep, replace with the other siren. Does anyone else think it sounds like the ignition beep, only outside?
  #80 (permalink)
Old 10-15-2008 | 06:39 AM
MAXIMUSQUO's Avatar
In the European car the new part works too . Thx for your information!
Max.
