SKREEM Options
Re: SKREEM Options
As I mentioned would have bought the $250 special but did not know what car might need. From what I have seen it is a security feature that seems to add more annoyance than security. With a ECU memory dump it should not be hard to bypass the function entirely.
That said while I have reprogrammed a lot of devices from GM cars to military aircraft, I have never taken a Merc apart, about all I know is that the ECU seems to have been supplied by Bosch and not what is inside it.
Now my guess would be that Needswings probably has an NDA in place that limits what they may do/tell. I don't but really do not know how to start. since I doubt that the CPU is a Motorolla/Hitachi 6809 or even an 8086.
Bottom line first I would need a test unit. Second I would need to buy/build a way to dump/load the memory (KESS ?). Since apparently there is not a DIY merc/crossie programming group, I would need to start from ground zero and could take several months to accomplish particularly if I have to build a test bed. Quick way might be a totaled car that still runs. Just a thought.
ps has anyone ever had or used a KESS/KTAG ? Am trying to figure out which one I need.
Re: SKREEM Options
Well following the dump will need to disassemble the program, identify the I/O, bypass the SKREEM, fix any checksums, and reload in the ecu but am just taking one step at a time. Is possible you may be able to R&R the memory chip if socketed but need to get an ECU apart first. Anyone have a junk ecu ?
Don't be so negative Moriarty.
ps have written disassemblers before.
Re: SKREEM Options
I'm a layman here on this...an interested lurker. Seems the geek folks here (and I use that term respectfully) have a sense of what it might take. It's almost like using reverse gear to understand what that SKREEM is doing. I'm sure this question has risen before, but what is actually failing inside that box...and is it heat related? Also, why couldn't the failed section/piece inside that box be repaired? The analogy I'm attempting to use here is the solder repair to the RCM. Again, I can't contribute to what Padgett is contemplating, just some random thoughts based on my reads on this forum in the short time I've been here.
Subscribed!
Regards,
Subscribed!
Regards,
Re: SKREEM Options
Subscribed!
Regards,
Subscribed!
Regards,
Re: SKREEM Options
My initial approach would be simpler, test the individual parts and look for a failed resistor, diode or something like that. These cheap as dirt parts fail and the world ends up with another electronics board replaced and one on the scrap heap. Find out which parts commonly fail and you have solved the riddle.
Wouldn't that be one helluva asset to the forum members (especially since the prices went galactic), if someone could figure this out with a simple fix/repair. I can dream, can't I ?
Re: SKREEM Options
Problem is that my understanding is the SKREEM includes a module that is interrogated by the ECM and has to return an encoded response (why each needs to be matched to a VIN). This is why I suspect it would be easier to reprogram the ECU. Was there any -320 Merc that did not have a SKREEM ?
Let's just say during my long career, several times I was given a box, told where it went, and had to figure out what it did. This is much simpler but if had to start from ground zero would have to either make or acquire a test bed to capture signals. But even before that would need to identify the internal components. Am sure schematics exist but right now am not sure is the ECU is a Bosch box or Siemans..
Just as a SWAG I'd target a $25k budget for the project (lots less than my retired-from employer would bid).
Re: SKREEM Options
I'll add some photos of the board inside.
Re: SKREEM Options
That MB part number comes back to a device in the drivers door https://www.mboemparts.com/oem-parts...IFJlc3VsdHM%3D
Re: SKREEM Options
Didn't think it would be easy did you ? Looks like a number of components under that grounded shield. Am sure there is a Mercedes document somewhere and "fair use" for training and education purposes is permitted under the DMCA (Digital Millenium Copyright Act). This would definitely be educational.
ps 5WK4 8698 comes back as an Immobilizer.
Re: SKREEM Options
Re: SKREEM Options
Just thinking but how does one steal a Mercedes, you would have to think like a car thief. I can't believe that the criminals haven't found a way around this problem. Or can we totally eliminate the theft protection and go back to a 60's ignition like an MSD or modern day MSD. Any ideas on this I have to assume everyone's Skreem will fail sooner or later.
Just found this in another post, a SKREEM repair source
http://modulegods.com/
CrossfireForum - The Chrysler Crossfire and SRT6 Resource > Cars > Crossfire Roadster
> Programming Skreem Module post #62
Re: SKREEM Options
I would think that it would be easier to build a new SKREEM from one of the microcontrollers on the market. I'm not saying to build one that actually does all the SKREEM does, but one that simply provides the response to the ECU that it is looking for.
I wonder what Josh Chase would say.... I think I'll go to Facebook and ask him.
Re: SKREEM Options
Re: SKREEM Options
I sent an email to SOS Diagnostics in Oregon and asked if they could repair or replace a Crossfire SKREEM. Told them I was asking for myself and on behalf of the Crossfire Owners Forum. I also found reference to a couple other places that claim to resolve SKREEM problems on a Sprinter forum. SOS sounded the most promising. I’ll report back if I get a response.
Re: SKREEM Options
I am in contact with Kasey at ModuleGods in Florida.
He says if we would send him a working set of SKREEM, PTCM and keyfob he can decode what needs to be reprogrammed in the PTCM to bypass the startup procedure.
( disable the SKREEM entirely )
Once that is done, all that needs to be sent to him is your PTCM, cost will be in the $200 range.
I have yet to find a volunteer to supply the 3 components - I can only assume there is a chance he might brick the PTCM.
Anyone want to play ????????
