Airbag Recall Parts In
Re: Airbag Recall Parts In
Open your passenger door and look at the end of the dash not seen when the door is closed. You will see the keyed switch, every Crossfire has one and it is used to turn the passenger air bag of when a child seat is used, maybe just the rear facing seat - check that statement.
Dealers lie all the time and some get what they are told mixed up because they do not know too much about cars.
Now at dealer. Think I have found someone willing to help. Was shown the Dash-III screen that did not show communications with ORC. No ORC. No error code.
They are now "checking further" - suspect R&R of module is in progress. Think they now understand that am serious and Will Not just go away. Told I already contacted CC and have case number, just have not identified the dealer as yet.
Stay tuned.
Stay tuned.
Re: Airbag Recall Parts In - Star Case for 2007 ORC
Back now and finally think we are getting somewhere but they do not seem have the right scan tool. Seems there is a Star Case on a failure to communicate (below) and are now trying to find the right one.
The underlying issue is whether I am the first to experience this or just the first to dare to question the dealer.
In any event suspect it is best for anyone here going in for the recall with a 2007 or 2008 to take a copy of this case with you in case of an airbag light the dealer cannot clear.
Major issue is that it has taken three trips and about 10 hours at the dealer to get to "we don't have the right tool".
ps what is a "StarScan" ?
I wonder why they want the iggy 'ON' before hooking the battery back up? Hooking a battery up to a 'LOAD' (IMHO) is both risky and unsafe. Risky because there is a possibility of a surge due to the car electronics being 'turned on' sequentially (by the ignition switch), and unsafe due to the sparks creating a surge (present when placing the clamp on said battery) with the car wanting a full load (unlike just the parasitic draw expected). I wonder WHAT they did to Padgett's car? Maybe they did this 'iggy on then battery' thing? I wonder IF they are feeding you the 'later' Jeep SRS code ( ANFSCD OBD-II Code CT1322A - Jeep Garage - Jeep Forum ), or does FCA use these 'hidden' codes in the MB ORC moduls as well?
Knowing what is in my 08 Vol 2 section 8 page 8-520/521 (SRS Verification Test), I would ask them to verify NO CODES are present BEFORE they touch mine. This way, if it isn't working afterwards, then FCA is CLEARLY 100% at fault. I also wonder if they could have PINCHED a wire during reassembly, causing this code? Did they try to 'reset' that present code? With all the members here who have replaced their wheel/bag, it cannot be that hard to do it WITHOUT hooking up the verification test, could it? The manual SHOULD have that test done BEFORE they touch anything (but that would cement liability wouldn't it?). THE SELF CHECK OF THE AIRBAG LIGHT IN CLUSTER SHOULD BE 100% AS TO THE INTEGRETY OF THE SYSTEM BEFORE SERVICE (lamp on after start/run, then off after @ 6 seconds WITHOUT lamp lit afterwards).
You have quite a risk buying a ORC (Occupant Restraint Controller) module off the internet, the service manual cautions not to drop or jar it because its accelerometer integral to that module may be damaged. You can read more in Vol 2 of the 08 service manual pages 80-522/523 OR whatever manual you have which may have a different page close to this one referenced. Since reading this post, I have read a lot of this entire section, and believe THEY (the guys replacing that airbag) did something out of sequence (maybe like that reconnection of the battery with the iggy on). IF they checked in that car with the airbag light off (or any reference to on or off), they most surely did something to pop that code up. The replacement mentioned/sequenced in that section of the service manual (same volume pages 80-533/535.
This makes me MAD as hell, they are trying to bend you over and not use lube. Oh aren't they so nice to 'reduce' the price they want to charge you? Get a printout of the error code (without letting them touch your car again) and take your car to another service department to 'reset' the entire SRS system. Sounds like your going to need a hand legally, good luck!
One ALSO has to remember the self test WILL tell you if you have NO PROBLEMS with the SRS SYSTEM before some clown at a FCA dealership starts monkeying with it (providing you don't have a problem before going in to have the air bag replaced under this recall). The service manual tells them to run their SRS Verification Test after they do work on the system when there is/was a problem, like an impact or other defect (not a system that is working correctly, only opened up for this recall). I plan on videotaping its 'self test' before they touch mine (based on the so called techs working on stuff they know almost nothing about to date). Most important, there are numerous posts here in the forum that members have replaced/removed their steering wheel/air bags for various mods WITHOUT any DRBIII/Star/Cables/software just by removing the NEG cable and waiting a short period of time for the system to 'discharge' stored electrical energy. Many (if not all) of them never had a problem afterwards.
I ask all those who replaced their steering wheel, did the paddle shift mod, or swapped their own airbags, did you check the SRS airbag light for its correct operation after you did the work (when no fault occurred upon completion)? Let us know, I am curious if the self check did not operate correctly OR if your SRS air bag lamp on your left cluster lit up continually
I will bet you padgett's car has that SRS lamp lit now. I would also bet it was not lit when he first brought his car in.
First time I've seen the airbag disassembled. Actually, replacing that module is actually what the recall is all about. Might make sense that the parts they needed were the modules and not the entire airbag assembly. I am really curious now. Mine gets repaired on the 22nd.
I'm more & more convinced that they will disassemble the airbag removing the potentially hazardous module, replace it with a new one, re-assemble & re-install in Crossfire. I'm guessing it will only take 60-90 minutes. No need to worry about color then. And it clearly shows that this airbag is designed different than the one Mrmiata shared with us. I wish I had the one like my spare unit above. Module is a "drop in" design rather than having to remove the entire backing plate. Much cleaner & simpler to do this repair. Wonder if the TRW connection is compatible with the connection for Takata? Can't really tell by these pictures.
Mine was like dedwards, it had two connectors on the back as I recall now. Pictures help you remember much better, normally I have trouble remembering what I had for breakfast.
But on the Takata airbag that Mrmiata posted, that backing plate has to be removed to get the module out. Way more involved to repair and somewhat weaker design. I can see where Takata sold an airbag design to Chrysler that was cheaper to make than TRW version. And I'm fairly certain the connector is different between the 2 versions.
You guys with 2004 - 2006 models really lucked out!
Otherwise it's your word against theirs and you know whose word they will take. Just say you want to make sure that they do not damage anything as you have heard other people have had trouble after the swap.
Say that the other dealers were probably not too careful, butter them up a bit.
Mechanics and service reps get a bonus on any extra work they get the customer to have done, needed or not. Some of these mechanics/reps have no conscience at all. One guy told me I needed a brake job, I said that is strange as I have just done one myself, he said not right now but soon.
Pending codes being some of them.
How do you know when dealers employee is lying?
Their lips are moving.
