storing car for winter
on
Re: storing car for winter
I suggest you remove your battery and take it to wherever you will be living and hook it to a battery tender where you can keep an eye on it
Also put about 9 ounces of Sta-bil fuel stabilizer into your gas tank and then top it off with premium and run about 10 miles before you park it for the winter
That is why I suggested he remove the battery and bring it to where he will be
Sta-bil is 1 ounce for 2 to 2.5 gallons so 9 ounce is good for 18 gallons
Just a bit more than our tanks hold at 16.9 gallons
A bit more is OK a bit less might not be as effective IMO
OP said he would not get to the car while in storage
I went out to the garage and checked the bottle (left over, the boat has been gone for about 8 years now) I thought the Sta-Bill was a 16 oz bottle. It was not. NOW, about the "Battery Tender" I think the car will be fine for two months on the tender. I prefer not to disconnect the battery. Your thoughts.
I do recommend that you have the tender plugged into a surge protector to be on the safe side.....That is what I do
Thanks Ed. Reply appreciated. I made a mistake, the bottle I had left over from my boating days was larger than I thought so I actually put about 16 oz in each boat tank.. I also have a alarm system at the house with cameras and switches. I think I will put the Tender on and be able to shut it of remotely from my phone, should I think it necessary.
Thanks Gary. As I said to Ed, I have switches that I can operate from my cell. That along with the surge protector is the way I will go. OH, and add the PROPER amount of Sta-Bil.
Isn't our biggest problem with gasoline today the Ethanol(more Hygroscopic, increased corrosion)? Sta-Bil use to be the go-to treatment for storage, but according to my trusted source, the better product to use is StarTron Enzyme Fuel Treatment (I have no affiliation what so ever with this product). My source is a trusted mechanic who also works on small engine equipment as well. He has used the test strips(before and after) and unlike Sta-Bil, claims it actually knocks down the Ethanol. All the other claimed benefits of the product are essentially the same(reduced gum/varnish,extends gasoline life,stabilizer,etc.) Also, if available in your area(and you can afford it; $7.50 a gal. for me here in CA.), Ethanol free 93 gasoline would be the best to run through the car and store it with. I look forward to any and all feedback about this.
