Need advice on possible pitfallswith low mileage Crossfires
I'm in the market for a low mileage Crossfire and there appear to be a good number of them out there--I was just looking at a 2007 Roadster with 5500 miles on it. What are the pitfalls associated with such a low-mileage car? From a reliability and cost of ownership point of view, show I be looking at higher mileage vehicles?
Re: Need advice on possible pitfallswith low mileage Crossfires
There are things that need attention due to time (coolant, brake fluid, hoses, battery) and things that wear with mileage.
I always look for low mileage cars and you can find Crossfires with less than 40k miles.
It also makes a difference how the car has been stored (garage) and driven.
I have owned three 04 Crossfires, buying each one with low 30k miles and the only mechanical issue I have had was a water pump that went bad at 35k (that could be due to age, since the bearings are under constant tension).
Some wear items are easy and inexpensive to replace (brake pads, tires) and some are prohibitive (engine, transmission).
These are reliable cars when treated properly.
If the price is right go for it. If the battery is original replace that. The main mechanicals are rock solid. If you see on the forum where it looks like our cars have lots of issues, they don't. Our problems are usually sensors and small electrical issues. Other than that look here.
KDW4Him
18
09-01-2021 06:47 PM
waldig
10-17-2015 12:39 AM
waldig
07-15-2015 03:05 PM
