SKREEM Module
Old 02-01-2015 | 11:56 AM
pv2haisch's Avatar
Default SKREEM Module
Where can I purhase a SKREEM module? Also, does it need to be reprogrammed?
Old 02-01-2015 | 04:08 PM
Default Re: SKREEM Module
It needs to be programed to suit your cars VIN.
Why? What is wrong with yours.
From an earlier thread on this forum.
.........Any how ordered from Factory OEM Parts in Tampa Florida. They asked Vin and Mileage then sent it.$145 Its the SIEMENS 1708201826 Plugged it in and car started. YEA. A Mercedes mechanic told me to turn to On then wait few seconds to program itself before engaging starter. Then had to program key to unlock doors. So it back on the road now.
$145 is pretty good if you ask me when you really need one.
Old 02-01-2015 | 05:47 PM
pv2haisch's Avatar
My skreem module is shuttin the car off while im drivin and then wont start for like 10 minutes after it shuts off. Does it randomly.
Old 02-01-2015 | 05:53 PM
Mrmiata's Avatar
Have you looked up the "mystery no start" thread?
Old 02-01-2015 | 05:54 PM
pv2haisch's Avatar
Ya i think so. I think thats where i got the skreem thing from. Why you got another idea?
Old 02-01-2015 | 06:00 PM
It is most certainly not the SKREEM.
If the engine does not turn over using the starter, I mean no engine movement at all. Look at the RCM.
If the engine turns over using the starter but does not start it is probably the CPS, of much less likely the Camshaft sensor.
Old 02-01-2015 | 06:10 PM
pv2haisch's Avatar
Okay, whats the RCM?
Old 02-01-2015 | 06:16 PM
Mrmiata's Avatar
Relay Control Module.. click Video RCM in my signature below..
Old 02-01-2015 | 07:07 PM
pv2haisch's Avatar
Ok. So i watched that video and the guy does the repair on an slk 230 is that the same module on the crossfire?
Old 02-01-2015 | 07:27 PM
Can we take it that the starter does not turn the engine over?
It is critical that the exact symptoms are explained.
Old 02-01-2015 | 07:29 PM
Mrmiata's Avatar
For the most part.. all technical intents.. it applies to our cars. Right hand drive car shown.. so "swap" sides of car.
And as 180 noted.. "exact" symptoms are required or we will be chasing "maybe's" for a while.
Old 02-02-2015 | 07:00 PM
pv2haisch's Avatar
Okay so the RCM is still practically brand new. But mt ground terminal was just about destroyed from corrosion so i changed it out and it made a huge difference. Starts up even quicker than before. So everyone on here is right, these cars do NOT like low voltage at all. Thanks for all your help guys.
Old 02-02-2015 | 07:07 PM
Mrmiata's Avatar
Glad we got you looking a little deeper into things! You would not be a happy camper having to deal with the skreem.
Old 02-02-2015 | 07:41 PM
pv2haisch's Avatar
Yeah for real that sounded HORRIBLE
Old 12-16-2019 | 08:54 AM
Put a fuel pressure gauge on it, sounds like low pressure to me.
My Ford Ranger is doing the same thing when warm, it takes a few seconds to build pressure.
This one is cheap and accurate, and is almost as easy to use as a tire pressure gauge:
https://www.summitracing.com/parts/otc-5630
It comes with everything you need.
Old 12-16-2019 | 08:58 AM
Even cheaper from Summit : https://www.summitracing.com/parts/w...display-detail
Old 12-16-2019 | 09:13 AM
Must be just an echo echo echo.
Old 12-16-2019 | 09:25 AM
Wadda you mean ?
Mark's was $34, mine was $22
Old 12-16-2019 | 10:22 PM
Old phart phred's Avatar
Just a 4 day old infant newb crossfire owner here, but multiple errors might point to the bad engine ground strap issues.
Old 12-17-2019 | 12:13 PM
Wadda you mean ?
Each of your gauges showed up on the same page, on pizzaguys page yours showed up as a small ad. On your page his showed up as a small ad. There were others with different prices as well.
Quick Reply: SKREEM Module
