Originally Posted by catman
If you check out MI Roadsters post of 3/23/2005 "What Color is Your Crossfire", the two color chips side by side are definitely not the same color.
Good observation. I think Chrysler has made it more confusing through the renaming. I'm not proclaiming to be an expert on Crossfire paint, but I'm still sure all red Crossfires are PRH, 591.
Here's an old thread where the "two" reds were compared in person:
https://www.crossfireforum.org/forum...erno+red+blaze
As they say in the commercials, "ask Sherwin Williams":
http://www.sherwin-automotive.com/fo...car_finder.cfm
When you search for Crossfire paint codes using this site, the only red you get for 04 or 05 Crossfires is 591, PRH. They call it Inferno Red, and not Blaze Red. Next, I did a search on paint codes for the 05 PT Cruiser. Note that two different Inferno Reds were available for the Cruiser in 05, though the three stage PEL paint was phased out in favor of the two stage finish. So what you end up with is the 591, PRH Inferno Red Crystal Pearl of the Crossfire and simply PRH Inferno Red Crystal Pearl for the Cruiser, 300, and other Chryslers. Now I'm not sure as to what the 2nd color is in MI Roadster's scan, but the first is Blaze Red, 591, PRH, aka Inferno Red Crystal Pearl. The second shade is either PEL, or PRH, but it is also called Inferno Red. Below is some info on the formulations for each of the three Inferno Reds. Another thing to consider is that since the Crossfire is built in Germany it is possible that the formulation is specific to finishes used there. But one thing's for sure all red Crossfires are the same color, so you can call it whichever you want and still be correct.
MFG Model OEM Code Formula Vehicle Part Color Name Year(s)
Chrysler Crossfire 591 , PRH 67116 Exterior Infrno Red Crystl
Pr 04 - 07
Chrysler Pt Cruiser PEL 49762,56148 Exterior Inferno Red Prl 02 - 05
Chrysler Pt Cruiser PRH 49762,63816 Exterior Infrno Red Crystl
Pr 05 - 07
Usage: 591 , PRH Chrysler, Crossfire (Ext) Color: Infrno Red Crystl
Pr
There are 2 records.
Formula Application Product Quality
U7 -67116 -Q Basecoat Ultra 7000
GB -67116 -C Basecoat Genesis Basecoat
Usage: PEL Chrysler, Pt Cruiser (Ext) Color: Inferno Red Prl
There are 4 records.
U7 -56148 -Q Groundcoat Ultra 7000
MBC-49762 Midcoat Ultra 7000
B7 -56148 -Q Groundcoat Ultra 7000 [New]
MB -56148 -Q Basecoat Motorcoach Basecoat
Usage: PRH Chrysler, Pt Cruiser (Ext) Color: Infrno Red Crystl
Pr
U7 -63816 -Q Basecoat Ultra 7000
