any size lug bolt you want
Old 04-01-2009, 12:00 PM
Default any size lug bolt you want
I just checked and i can get any size lug bolt you want, here are some pic of some of the ones i can get ,,
stock size too. the ones with the round head uses a special socket that fits it,,the socket is $8.00 the lug bolts are $3.00 ea,, if you know the length let me know,, if you don't know the length ,, take a stock bolt put it into a stock wheel looking at the back or it measure the lenght sticking through ,,, then useing the same bolt stick it into the new rim and measure how much is sticking through,, if sticking through 1/4" more than stock then measure the stock bolt minus the 1/4" and you have your new size. hope this helps. shipping will be extra. jim
Old 04-01-2009, 12:50 PM
mrphotoman's Avatar
Default Re: any size lug bolt u want
that is pretty cool, do they just cut down the bolts to any length?
lets say I wanted .8" of threads they could cut them that length?
If the wheel spacers i bought do not work then i will pick up a set of these.
Old 04-01-2009, 01:12 PM
I may be in for a set. I noticed you said they needed a special socket, would these be considered locking hubs or is the head not that specialized and anyone could get them off?
Old 04-01-2009, 01:23 PM
they are not,,, not cut , they are ordered that way.,
Old 04-01-2009, 01:24 PM
the socket fits the head ,, it is not locking because there was a box of the sockets and all were the same..
Old 04-01-2009, 01:25 PM
tom2112's Avatar
She can ride with me ;)
I definitely need a set of ten lug bolts. I need to measure the stock bolts against my drag wheels. As soon as they come in, I'll let you know what size I need.
To specify the size, all I need to give you is the length of the threaded part of the bolt right?
Old 04-02-2009, 07:01 AM
mrphotoman's Avatar
stock size too. the ones with the round head uses a special socket that fits it,,the socket is $8.00 the lug bolts are $3.00 ea,, if you know the length let me know,, if you don't know the length ,, take a stock bolt put it into a stock wheel looking at the back or it measure the lenght sticking through ,,, then useing the same bolt stick it into the new rim and measure how much is sticking through,, if sticking through 1/4" more than stock then measure the stock bolt minus the 1/4" and you have your new size. hope this helps. jim
is the thread length on the 2nd one down .8125"?
Old 04-02-2009, 07:09 AM
today i will get the measurement in mm from the fractory that makes them.
is the thread length on the 2nd one down .8125"? not sure, jim
Old 04-03-2009, 07:12 AM
it is .8600.
Old 04-03-2009, 07:19 AM
I am tring to scan and post pic from the book all the different sizes, and cone seat or ball seat we use cone seat some wheels use ball seat i have both, here are the lengths of the bolts i can get, jim
.86= 21.84 mm
.93= 23.62 mm
1.02= 26.00 mm
1.10= 27.94 mm
1.18= 30.00 mm
1.22= 31.75 mm
1.25= 30.99 mm
1.38= 35.00 mm
1.55= 39.37 mm
1.575= 40.00 mm
1.97= 50.00 mm
2.36= 60.00 mm
Old 04-03-2009, 08:37 AM
mrphotoman's Avatar
how long does it take to get them in and how much is shipping?
Thanks
Old 04-03-2009, 11:25 AM
1 to 10 days to get them 1 day for most because they are in stock for 10 lugbolts shipping would be close to 7 ,,just say $7.00 U S only shipping for 10 would be 12.00 U S only shipp out of us ,,i can give you the rate when u pm me. jim
Old 04-07-2009, 06:11 PM
Default Help!!!
I have a race this weekend and I need 20 bolts ASAP!!!!!!!
20 Qty 26.00mm Cone Seat I can easily go +1 or -2 sizes on 10 and +2 to -2 on the other 10 if it makes them all ins stock. HELP ME WIN!!!
I PM'd you my Phone #.
Old 04-21-2009, 06:28 AM
Default Re: Help!!!
sent the bolts, did you get them in time for the race ,,and did they fit correctly.. jim
Jonacross
20
07-17-2017 11:19 PM
onehundred80
08-06-2016 12:03 PM
onehundred80
09-07-2015 05:49 PM
jaesa
09-07-2015 01:50 PM
2004_
09-04-2015 01:39 PM
Quick Reply: any size lug bolt you want
