185/181 LET pulley kit, LET heat exchanger, and more for sale!
Old 02-19-2009, 12:20 AM
240M3SRT's Avatar
Default 185/181 LET pulley kit, LET heat exchanger, and more for sale!
LET 185/181 pulley kit with version 2 water pump pulley. You can swap back and forth between the 181 and 185 pulleys, hub stays on the crank. Its like getting 2 pulleys for the price of one. SOLD!
2.5" Modified manifolds. Includes upgraded couplers. SOLD!srt6partsforsale003.jpg
Old 02-19-2009, 12:31 AM
Default Re: 185/181 LET pulley kit, LET heat exchanger, and more for sale!
Sent ya a pm! Thanks.
Old 02-19-2009, 01:02 AM
240M3SRT's Avatar
LET Heat exchanger. I had the brackets custom welded and fitted myself for perfect fitment of this particular unit. $250 shipped.
Rear cat delete(local only). Stainless steel 2.5" TIG welded sections. Keeping it for now...
Stock exhaust manifolds. Fitted with secondary o2 bung for accurately monitoring A/F ratio. SOLD one keeping the other for now...srt6partsforsale006.jpg
Old 02-19-2009, 01:26 AM
240M3SRT's Avatar
JR Industries triple pillar pod, professionally painted gloss black, holes already drilled for gauges. SOLD!
AEM electronic A/F ratio gauge(1 available), $135 shipped
AEM electronic boost gauge, SOLD!
AEM electronic fuel pressure, $135 shipped
Old 02-19-2009, 01:48 AM
jturkel's Avatar
will the modified manifolds fit on the C32? i'm guessing they are internally modified, not externally(larger) like the needswings (or am i making stuff up)?
also, can the phenolic spacers be used with an SL55 intake? i have no idea where these get installed.
would you part with just one of the pulleys instead of as a package deal?
Old 02-19-2009, 02:14 AM
240M3SRT's Avatar
Originally Posted by jturkel
will the modified manifolds fit on the C32? i'm guessing they are internally modified, not externally(larger) like the needswings (or am i making stuff up)? C32 yes but you may need modified intake. The biggest restriction is the runner with is a tiny 1"...these are increased to 2.5". I have tested various setups and not seen less than 10whp, but up to 20whp with other mods.
also, can the phenolic spacers be used with an SL55 intake? i have no idea where these get installed. yes, its easy you can do it yourself or a shop should charge .5-1hr
its a pkg deal, only 1 hub so it would be pointless.
Old 02-19-2009, 02:38 AM
Hi 240,
what's going on? Do you want to get your car back to stock and sell it ?
Old 02-19-2009, 07:06 AM
Originally Posted by SLK32Germany
Hi 240,
x2...??? someone is going to get a good deal on this stuff!
Old 02-19-2009, 08:55 AM
BlUEMDsrt6's Avatar
I think 240 is about to go turbo.
Old 02-19-2009, 09:23 AM
Bulldogger's Avatar
If you're going turbo no need to get rid of the gauges??? I say he's thinking sell.
Old 02-19-2009, 10:31 AM
240M3SRT's Avatar
Fellas, i have hit what i think is the max power i can obtain from the car on the stock supercharger without being further bent over by the law of diminishing returns. Headers are off the car(i pulled them in a little over 2 hours, i guess thats from doing it so many times, lol. )
I wont sell the car due to the rediculous drop in value. Its not like i really wanted to sell it anyway, but i cant say the though never crossed my mind considering the next stage...
Old 02-19-2009, 10:57 AM
BLKFIN's Avatar
ADDICTED TO BOOST
I hate to see you do this, but I understand.
Old 02-19-2009, 11:15 AM
KrzyFast's Avatar
Drop the new 6.4L Hemi in it and call it a day - 525HP/515TQ-FI or 540HP/490TQ-Carb. Pick up where Lantana left off.
Kidding aside, I hope your new direction pans out for you and gets you where you want to be in the HP dept.
Cheers,
KrzyFast
Old 02-19-2009, 11:27 AM
jturkel's Avatar
a modified intake? like an SL55 intake setup (that i have) or some other kind of modification?
Old 02-19-2009, 12:09 PM
240M3SRT's Avatar
I believe MikeR is running the SL55 intake with my manifolds. However, the firewall is a little closer on c32. You might need a single tube.
Old 02-19-2009, 12:11 PM
jturkel's Avatar
yes, the firewall is much closer. the SL55 splutter barely fits. what do you mean by "a single tube" ?
Old 02-19-2009, 12:17 PM
240M3SRT's Avatar
A single tube intake. The manifolds will bolt right up but you might have to make a custom intake. Code3 put my intake plenums on a customers car and they worked fine, but im not sure what he did for the intake.
Old 02-19-2009, 12:54 PM
I have Shelton's modified intake manifolds, Code3 phenolic spacers w/NW gaskets and SL55 intake system. It all fits just fine and works great. Two more weeks and I get to test it all with the DR's....
MikeR
Old 02-19-2009, 03:03 PM
240M3SRT's Avatar
MikeR
Thanks for the info Mike. Looking forward to seeing your times at the track!
Old 02-19-2009, 03:10 PM
SRTpowa's Avatar
MikeR
So your previous best of 12.2 was prior to the modified manifolds correct? I'm about to take these off shelton's hands and I would think they would put us close to 11's.
Quick Reply: 185/181 LET pulley kit, LET heat exchanger, and more for sale!
