178mm ASP Pulley Kit for sale
![Default](https://www.crossfireforum.org/forum/images/icons/icon1.gif)
Because all the fast cars have them
and if you want to get in the 11's you'll need something like this.
Also it's half price, cant beat that.
http://www.mbworld.org/forums/engine...amg-450-a.html
![Razz](https://www.crossfireforum.org/forum/images/smilies/icon_razz.gif)
Somewhere in the back of my mind I've fantasized about using a 178 with my code3 pulley. As I remember someone tried that with his 181 (tighed1?). I wonder if that's a recipe for a destroyed engine or within the realm of off track daily driver. I guess it would depend on how cool you could get the charge. What do you think?
Originally Posted by jturkel
i actually thought about snagging this for the same reason....then i remembered there is a post i think on this forum regarding the maximum safe S/C RPM and running both the 178 and Code3 brings it to unsafe levels where the life of the supercharger is greatly diminished and is very detrimental to the supercharger.
If it hadn't been a terrible year I wouldn't think twice but $450.00 seems like a lot of dough right now and I've been writin' checks like a maniac. Maybe it's prudent to let it go. Nice price though!
I appreciate the input! We'll have to research this a bit
Well guys I did both pulleys and ran out of fuel. With the 178 pulley Iam edging a bit over 20 psi at the INTAKE MANIFOLD sensor-----not at the WYE. The code 3 was much more and you could feel it till the motor went flat at the high revs. When I installed the data logger you saw the a/f just drop off.
THe fuel air mixture was immediately hitting 17 to one and I need to get to a tune, but the idler pulley fix has taken presidence for now.
You need much more fuel in the map to allow the pair of pulleys as the boost would be way over 20 PSI and the car will lean miss and throw codes. This is one of the first things that 2009 will bring me into, the tune and how it does.
Does anyone know if the engine at WOT is running in closed loop or open loop mode??
It would seem to be open loop, from the responce.
Enjoy WOODY
Enjoy WOODY
![Confused](https://www.crossfireforum.org/forum/images/smilies/confused.gif)
I'll be glad when someone gets this all figured out. My Code 3 is just sitting there begging me to install it!
Do you think that there is really a BIG problem with running both pulleys as long as you aren't running max boost/rpm but for moments at a time as in city driving?
I did not experience any cutting out and did not get any codes while running stacked at the West Coast Shootout.
Just wondering...
What's the easiest (cheapest) way to monitor A/F ratio?
Just wondering...
I have the asp wp pulley and it is a solid beast, NTF on that one.
Running both pulleys are ok if you stay out of it, but how do you stay out of it??? The data logger is a few hundred and lots more in time to interconnect the lines to the various points, I like the Zetronix and the spread sheet of results that is outputted for data.
Woody Enjoy
Woody Enjoy
it is not safe for the s/c to run both pulleys.
see this thread: https://www.crossfireforum.org/forum...ight=S%2FC+RPM
check posts 8 and 14
Originally Posted by MikeR
Since it says it is an ASP pulley kit then there is no 'old style' to worry about that I am aware of. That was with the LET pulley kits. That WP pulley does look very similar to the LET though.
MikeR
MikeR
LET's "v1" WP pulley and idler pulley are essentially identical in design to the parts offered by ASP. The one major difference with the WP pulley was LET's material choice of aluminum, vs. ASP's pulley being steel AFAIK. I believe LET decided to stick with aluminum for their "v2" WP pulley, but rework the design to incorporate more material in the stressed areas, as opposed to leaving the design alone and spec'ing steel for the material used, like ASP. From what I gather, so far so good - haven't heard of any "v2" LET WP pulley failures...
Enjoy WOODY
Enjoy WOODY
![Cool](https://www.crossfireforum.org/forum/images/smilies/icon_cool.gif)
Originally Posted by cruzinquick
Actually your not so maybe talk to them first. Airfrc on mbworld is selling his C32 with all your mods, injectors, and more. So maybe he knows something the rest of us don't. Even has your mani's.
do you know why Airfrc is selling his C32? I think he posted some interesting pictures about his new IC with water-meth injection...
Happy New Year to all here on the board!!
interesting results posted on mbworld regarding running dual pulley setup, larger injectors, and tune
http://www.mbworld.org/forums/c32-am...more-come.html
