Re: !!! LET Motorsports Pulley Failure !!!
Originally Posted by 70GT6
Checked NSK site and they do not even list a 6303z..
Bearings listed are 6303,6303DDU, 6303NR, 6303VV, abd 6303ZZ.
The ZZ looks to be the correct bearing, as both sides have a sheild.
If this is the correct part, the bearing is listed as "Speed Limit" (grease) 15000 rpm
Interesting - I'm looking at my stock idler pulley and the bearing is marked with a "6303 C3" and the green seals are stamped with "6303 RDD" but with a different type of seal then the bearings used on the LET or ASP (they look impervious to debris)
Now - if "speed limit" is 15,000 RPM - then we have a problem Houston!!
The stock idler pulley is approx 90mm
(178 / 90) = 1.978 * 6,000 engine RPM = 11,667 idler bearing RPM
(181 / 90) = 2.011 * 6,000 engine RPM = 12,067 idler bearing RPM
(185 / 90) = 2.056 * 6,000 engine RPM = 12,336 idler bearing RPM - No problem here.
The LET idler pulley is approx 60mm (and if the ASP idler is the same size):
(178) / 60) = 2.967 * 6,000 Engine RPM = 17,800 idler bearing rpm
(181) / 60) = 3.017 * 6,000 Engine RPM = 18,100 idler bearing rpm
(185) / 60) = 3.083 * 6,000 Engine RPM = 18,498 idler bearing rpm
Can someone verify the ASP idler pulley size and bearing used?
Looks like someone didn't do any math and just copied the OEM bearing part number...
